Old 08-23-2021, 10:50 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
P2119 code
I usually only run e85 but the delivery got delayed/late so i put 93 in and my car got mad and threw a p2119 code. Im positive its not tune related because my man zach at CSG did his blessings. I got it straight i just checked the throttle-body reconnected and cleared codes no more codes so far but just curious anything weird like that ever happened to you when doing a sudden switchover to octane
IsaiahW is offline   Reply With Quote
Old 08-24-2021, 11:09 AM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Did your car hit limp mode or anything? Or was it functioning normally when the code came up?
Dzmitry is offline   Reply With Quote
Old 08-24-2021, 11:11 AM   #3
IsaiahW
IsaiahW's Avatar
Limp mode it struggled bad and cut off twice while driving before i pulled over
Old 08-24-2021, 11:31 AM   #4
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
You running flex fuel or did you flash to another tune? If you reflashed, what procedure did you go through before reflashing and how much e85 was in the tank when you refilled?
CincyJohn is offline   Reply With Quote
Old 08-24-2021, 11:32 AM   #5
IsaiahW
IsaiahW's Avatar
P2119 code
I have a delicious tuning flex kit and i was on E it was about 38% ethanol
Old 08-26-2021, 02:28 PM   #6
p1l0t
p1l0t's Avatar
Totaled.
Old 08-27-2021, 10:32 AM   #7
Dzmitry
Dzmitry's Avatar
I would think it should have nothing to do with switching over fuels when you're on a flex kit. Could be that the TB just had a hiccup. But I would think if that was the case, it could be faulty and may happen again in the future.
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 04:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
CEL P2109 P2119 driftking96 Issues | Warranty | Recalls / TSB 2 02-15-2016 06:24 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
