Old 08-22-2021, 09:29 PM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
What’s the best way to monitor your baby at the track
So I have an iPhone. Check.
I have an OBD2 Scanner with a bluetooth that will talk to my iPhone live on the track. Check.
How do you guys post that up so you can see it while your driving?
I’m on my 7-8th or so track day so I really need to start monitoring this stuff so I can start watching my temps.
Don’t flame me. I know I’m a bit behind the ball at this point I just want a solid way you guy post up your phone or whatever you guys use so you guys can see the way your cars are behaving at when you’re starting to stress it at the track.
Thanks as always.
Jstyle is offline   Reply With Quote
Old 08-22-2021, 10:43 PM   #2
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Honestly, the next best investment I think that does it all with lap timing and car data is an Aim Solo DL. The 1st Gen units come up used often and just by plugging into the OBD port with it and mounting to the windshield with a RAM mount you can get oil temps etc and lap times all on one screen. You get to choose what you want to look at and can customize the screens.
It’s an expensive piece but we’ll worth it if you plan on going further. And if you hate it, they always hold their value and can easily be resold.
If you aren’t ready to take that leap. RAM brand mount for the phone is still the best way to keep it stable
Kelse92 is offline   Reply With Quote
The Following User Says Thank You to Kelse92 For This Useful Post:
CSG Mike (08-25-2021)
Old 08-23-2021, 02:03 AM   #3
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You have 2020 with Android Auto, right?
If you're willing to invest into a cheap rootable Android phone, you can Screen2Auto cast RaceChrono on the head unit, and set up virtual gauges for whatever parameters you want there.
Here's the lap timing screen on my head unit:
timurrrr is offline   Reply With Quote
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
beltax90 (08-25-2021), Kelse92 (08-23-2021), TommyW (08-24-2021)
Old 08-24-2021, 02:33 PM   #4
iag48st
Drives: 10Series 0945
In for info.
I have oft but its so big and bulky/heavy and I use Harry Laptimer on my iPhone so that's 2 devices that I need to worry about. Wish I could monitor temps and lap times on my iPhone.
iag48st is offline   Reply With Quote
Old 08-24-2021, 02:57 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Does HLT still not support custom OBD PIDs?
RaceChrono FTW.
Old 08-24-2021, 03:42 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm really not a fan of the Solo after seeing what @timurrrr has shown racechrono can do.
Racechrono app
XGPS160
OBDLink MX+
Way less then what the solo costs, does the same if not more, and don't need to hook to a laptop to see lapping data. I'm ditching my Solo as soon as the new battery for it shows up. Much happier with the racechrono setup.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (08-24-2021), timurrrr (08-24-2021)
Old 08-24-2021, 05:15 PM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I really recommend not taking your babies to the track until they’re no longer in car seats.
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
Dzmitry (08-27-2021), NoHaveMSG (08-24-2021), timurrrr (08-24-2021), Wally86 (09-03-2021)
Old 08-24-2021, 05:38 PM   #8
DarkSunrise
DarkSunrise's Avatar
For engine health, I've found it really helpful datalogging on my OFT at the track. I usually set the main screen to monitor knock correction (KC), with fine learning knock correction (FLKC) and advanced multiplier in the smaller windows. By monitoring knock, I know if I need to back off for whatever reason (large knock events or AM dropping). For example, I can usually see when I've lost or am about to lose a coilpack (increased FLKC above 6000 RPM). I can also review logs to see max oil and coolant temps (or set real-time alarms on the OFT itself).
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Jstyle (08-27-2021), NoHaveMSG (08-25-2021)
Old 08-25-2021, 08:58 AM   #9
Jstyle
Jstyle's Avatar
Drives: 2020 86
LOL… It’s hilarious, they keep making me want to take my car seat out every time I go through tech. I keep it back there that way ever time I look in my rearview, I remember to not be an idiot and I need to go home in one piece.
The Following 6 Users Say Thank You to Jstyle For This Useful Post:
dowroa (08-25-2021), Dzmitry (08-27-2021), gcranston (08-30-2021), jflogerzi (09-01-2021), Wally86 (09-03-2021), Yoshoobaroo (08-25-2021)
Old 08-25-2021, 08:59 AM   #10
Jstyle
Jstyle's Avatar
Drives: 2020 86
One more question, can I just leave my OBD2 scanner plugged in or do I have to plug and unplug it every time I turn on and off my car?
Old 08-25-2021, 12:16 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Depends on which one you use, but the 2 Bluetooth ones I have, you can not leave them plugged in for extended periods of time. For the day, you can leave it plugged in. Leaving it plugged in long term pulls down the battery.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Jstyle (08-27-2021), strat61caster (08-25-2021), timurrrr (08-25-2021)
Old 08-27-2021, 06:13 AM   #12
Jstyle
Jstyle's Avatar
Drives: 2020 86
So I’m looking for knock correction as a data point as an available field in my car scanner app… is that literally what it’s called?
Old 08-27-2021, 01:32 PM   #13
DarkSunrise
On the OFT, each of the data channels is labeled as I listed it earlier, but I’m not sure how those fields would be listed on your car scanner app (or if your app would be able to monitor those knock indicators).
If knock is something you’re interested in monitoring real time (and/or data logging), it’s probably easiest to pick up a cheap used OFT device and find a good way to mount it in your car.
2022 BRZ Build
2013 FR-S Build
Old 08-27-2021, 04:28 PM   #14
Advance Multiplier
Jstyle (08-27-2021)
Baby on the way - any good convertible baby seat recommendations? H_K Cosmetic Modification (Interior/Exterior/Lighting) 26 04-29-2021 08:37 PM
E85 and MPG monitor brillo Software Tuning 12 07-25-2017 10:12 AM
Oh baby- "Baby Driver" movie with a Twin sighting! stevesnj Off-Topic Lounge [WARNING: NO POLITICS] 29 07-22-2017 01:26 PM
ANYONE SELLING A GTS MONITOR OR OTHER aymen23q Australia Classifieds 2 01-20-2013 05:54 PM
