Old 08-22-2021, 12:22 PM   #1
Yetti
Drives: FRS
Air Fuel ratio not hitting target ECUTEK
Can't seem to figure out why the engine will not hit near target air fuel ratio at WOT. I changed the Fuel map and moved "engine load limiter #1" and "engine load limiter #2" out of the way. Is there another fuel table or load limiter that I do not know of?
Tuning with ECUTEK, car has intake, full exhaust and is running on 93 octane
Yetti is offline   Reply With Quote
Old 08-23-2021, 03:13 AM   #2
steve99
Answer is likely "car has intake"
intakes often cause tha mas air flow sensor to read incorrectly amd you need to recalibrate the mas air flow sensor scaling to work with ghe intake.
The maf is one of the primary sensors and effects fueling but also the load calculation that determines almost everytnig the ecu does so very important to get maf scaling correct or move to hybrid speed density
jcw99 (08-23-2021)
Old 08-23-2021, 03:15 AM   #3
steve99
also note that stock 02 sensor scali g will only read to 12.1 afr max rich
that will be your next issue
and if your running petrol that afr target looks lean even if its NA
Old 08-23-2021, 05:31 AM   #4
Yetti
Drives: FRS
My bad forgot to include there has already been some MAF scaling work and it is pretty close at idle and cruising (within a few %).
Old 08-23-2021, 08:06 AM   #5
steve99
You do both open and closed loop maf scaling ??
what intake is on car ??
is you maf scale fairly smooth if you graph it
wgen you add racerom it uses racerom load limiter table can you see that under racerom maps ?
Old 08-23-2021, 08:38 AM   #6
Yetti
Drives: FRS
Grimmspeed intake, it is the same diameter as stock and close to stock MAF scaling. The Maf scale is a smooth curve if graphed. This was with Racerom 12.1 and I didn't know there was a racerom load limiter I will check that in the tune.
PI ratio issues with ecutek and FI Drake_93 Software Tuning 2 09-13-2020 04:34 PM
Ecutek showing boost target hitting 19.9? incutebus Software Tuning 4 04-12-2019 12:22 AM
FS: Zeitronix Air-Fuel ratio sensor and gauge armyoffoo Engine, Exhaust, Bolt-Ons 23 12-12-2018 03:40 PM
Air/Fuel Ratio for Stock FRS @ High RPM Decimus Engine, Exhaust, Transmission 15 08-14-2015 02:20 AM
Crickets possibly fuel pressure target? Tromatic Software Tuning 1 12-16-2014 03:58 PM
