Old 08-20-2021, 05:21 PM   #1
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
What to look for when buying a used engine
Looking for some tips on what I need to be looking for when buying a used engine via FB marketplace or Craigslist. Spun rod bearings seem to be the common problem but I have no idea how to diagnose that if I'm just looking at an engine that's been pulled (not possible).
Are there any signs or indicators that an engine was abused? Is it worthwhile to learn how to run a compression test?
demasrv is offline   Reply With Quote
Old 08-20-2021, 06:52 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I'd never buy a used engine. Guys have decent luck sometimes however with the cost of labor to replace it you can end up doing it twice if you get a bad one. IMO just get yours rebuilt then you know there aren't issues
The Following 2 Users Say Thank You to TommyW For This Useful Post:
BrahmaBull1990 (08-26-2021), x808drifter (08-20-2021)
Old 08-21-2021, 05:24 PM   #3
demasrv
demasrv's Avatar
I can't find a shop that'll just rebuild mine, so I'm either rebuilding it myself or dropping a new engine in.
Old 08-21-2021, 07:40 PM   #4
Grady
Grady's Avatar
I would agree with the new block or building it yourself. For used look for low mileage and no modifications to the car if possible.
Old 08-23-2021, 11:08 AM   #5
demasrv
demasrv's Avatar
Originally Posted by Grady View Post
no modifications to the car if possible. .
That seems to be the impossible part!
Most of the engines I'm looking at, guys want ~$,3800+ for. At that price, I could pay for a new short block ($2k), get my heads reconditioned and after the gaskets and everything have a fully rebuilt engine for just over $3k. I've never done an engine rebuild on anything bigger than a 4 stroke before though.
The engine is all but pulled at this point, just need to unbolt from the motor mounts and take out the bellhousing bolts.
Old 08-23-2021, 12:39 PM   #6
TommyW
TommyW's Avatar
You're on the right path. The sealing of the timing chain cover is one of the most critical steps so research the procedure.
Old 08-23-2021, 04:29 PM   #7
demasrv
demasrv's Avatar
Thanks. I've heard that (timing cover), other sealant application and tightening down the heads are where I'll need to really take my time.
What's the best way to determine if my heads needs to be reconditioned? Can I just take these heads to any shop that reconditions them? Preference would be to not have to mess with valves/springs/rockers etc
Old 08-23-2021, 05:01 PM   #8
TommyW
TommyW's Avatar
Not just any shop. Get one that does total reconditioning of all related parts. You'll get everything back and ready to bolt back on
Old 08-23-2021, 07:13 PM   #9
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
It is a 4 Stroke
gen3v8 is offline   Reply With Quote
The Following User Says Thank You to gen3v8 For This Useful Post:
x808drifter (08-23-2021)
Old 08-26-2021, 12:10 AM   #10
demasrv
demasrv's Avatar
Originally Posted by gen3v8 View Post
It is a 4 Stroke
Fair! Ha! How about nothing bigger than a generator or pressure washer engine lol.
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 03:32 PM
Is buying a used brz more beneficial then buying a new one? Jcas BRZ First-Gen (2012+) — General Topics 60 10-20-2017 01:15 AM
Buying BRZ with replaced engine PSim Engine, Exhaust, Transmission 14 10-21-2016 04:06 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
