Old 08-19-2021, 09:56 AM   #1
H_K
Drives: '13 Scion fr-s
Quite smelly exhaust after header install + OFT Stage 2+ tune
Aside from the header, which is a JDL uncatted UEL, I have a completely stock exhaust all the way back.
I know that since I removed a cat that my exhaust might get a bit smelly, and with the OFT Stage 2+ tune I know that my engine would be consuming fuel differently.
However, what I didn't expect, was that my car's exhaust would get so smelly.
I have a pretty enclosed single car garage, and if I reverse into it, the smell is almost too much.
Is this a problem with the tune? I am fairly sure there's no exhaust leak. It seems to be running extremely rich.
H_K is offline   Reply With Quote
Old 08-19-2021, 10:11 AM   #2
Ashikabi
Ashikabi's Avatar
Uncatted exhaust is pretty gross smelling. While it's possible you're running rich, you should be able to verify that with the OFT. A significant change in smell is normal though. If you run E85, it will smell very sweet. Much more pleasant.
Old 08-19-2021, 10:49 AM   #3
H_K
Follow-up question - how bad for my health is running this? When reversing into the garage, the smell completely takes over and lingers for quite a while, even with the garage open.
Old 08-19-2021, 10:58 AM   #4
Ashikabi
Ashikabi's Avatar
Well it's not good for you. But it wasn't good for you before, just harder to notice. There are more chemical compounds in the exhaust floating around your garage than there were before, which is what you're smelling. For the few seconds your breathing it, I'm confident you'll be ok. But you really have to decide for yourself how much "risk" you're comfortable with. I consider it a "cost of having a racecar" so it doesn't bother me. Wouldn't stand around in the garage with the car running though
Old 08-19-2021, 11:50 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Don't idle in your garage before leaving. As well, if you are worried about health I'd suggest putting a header on with a high flow cat. As for the lingering oder, thars just part of it. The harmful gasses usually dissipate pretty quickly so long as theirs proper venting.
MS, CSCS, TSAC-F, CPT
Old 08-19-2021, 12:38 PM   #6
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
One of the perks of E85. It’ll still kill you, but you’ll enjoy the odor.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 08-19-2021, 12:42 PM   #7
Ashikabi
Ashikabi's Avatar
If I had to guess, there is likely slightly less chemical agents in e85 exhaust than gasoline. So it's less likely to give you lung cancer in 60 years
Old 08-19-2021, 12:48 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Based on the dynamometer data, the average difference in tailpipe emissions for E85 versus gasoline is -23% for NOx, -30% for CO, and no significant difference for hydrocarbons (HC)
You won't die as fast if you decide to take a nap in the car while warming it up in the garage either.
Old 08-19-2021, 12:50 PM   #9
Ashikabi
Ashikabi's Avatar
"switch back to gas before suicide attempt" got it. Thanks buddy!
Old 08-19-2021, 01:48 PM   #10
Capt Spaulding
Persona Non Grata
Gotta get that FF tune.
Old 08-19-2021, 03:12 PM   #11
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It's worth data logging with canned tunes. My car ran rich with the stg2+ tune.
Old 08-19-2021, 04:02 PM   #12
Grady
Grady's Avatar
I love the smell of E85 in the morning!
Old 08-19-2021, 04:21 PM   #13
Purist
Purist's Avatar
Drives: Subaru BRZ
So do all my neighbours, especially in winter.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 08-19-2021, 10:26 PM   #14
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I'm not sure what it is, but manufacturers put some kind of coating on new components. Most of that will burn off after a few heat cycles. My new Borla header smelled terrible for a short time. It's barely noticable now.
Qwimby1 is offline   Reply With Quote
What is the recommended tune for header install? Artxjr Engine, Exhaust, Transmission 12 04-08-2019 03:00 PM
Calibrating my Stg1 tune after 4-1 EL header install freerunner Software Tuning 51 08-20-2018 12:38 PM
quieter exhaust after stage 2 tune jslack Engine, Exhaust, Transmission 12 05-22-2018 03:04 PM
Catted Header or Stage 1 Tune first? Mr.Impreza Engine, Exhaust, Transmission 12 09-04-2015 05:35 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
