Old 08-11-2021, 04:44 PM   #1
Trev6450w
Drives: 2013 Black FRS 6MT
Camber Help
I have a 2013 Scion FRS, and when I bought it originally, it was a slammed car. 19-inch rims, and Eichbach Sportline Lowering Springs, Adjustable Control Arms, everything.
I've realized even though I loved the look of the car, I need to make it a more driveable/usable car for daily driving. Scraping was getting annoying.
I went ahead and sold the 19-inch rims, and bought some 17x8 O.Z. Alleggerita HLTs, got some 225/45ZR-17 Continental Extreme Contact DWS 06 Tires, and I am now raising the car up with some RSR Down Springs. I believe the RSR Down Springs lower the car around a little over half an inch.
I'm not too familiar with camber at all, and now that the car isn't as slammed. I would like to get some camber upfront and in the rear so I can still have some fun-spirited driving in the corners, but also maintain a somewhat daily drivable setup.
Opinions on what degrees I should be running both front and back?
Trev6450w is offline   Reply With Quote
Old 08-13-2021, 10:46 AM   #2
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
From some guy on the internet; for daily driving with a spirited run sprinkled in here and there I'd say somewhere in the 1-2 degrees up front and probably 1 degree out back.
I've got 3+ up front and 2+ in the rear but that's because I was going to be doing a fair amount of track with it (plans changed). Now I'm thinking of figuring out an alignment closer to 1.5 up front and then adjust the camber plates myself for 3+ when I got to the track (need to balance toe so I can manage maybe a bit of toe in up front for street but then a bit of toe out at the track. Seems like it could work).
CrowsFeast is offline   Reply With Quote
Old 08-18-2021, 12:19 AM   #3
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
I don't remember exactly where it was as its a big thread, but there is a thread in the suspension part where lots of gurus like RCE were posting.
There were some great recommendations with reasoning in there
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 08-18-2021, 12:27 AM   #4
fminicooper
Drives: FRS Hot Lava
IMO, no more than 2 degress front (anyways it will be less than 2 with combination of camber bolts)
I have achieved 1.8 max in the front with camber bolt and lower OEM bolt placed at upper hole.
Rear was less than 2 after lowering .75 inch.
fminicooper is offline   Reply With Quote
Old 08-21-2021, 07:11 AM   #5
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Alignment specs
OEM Specs
Camber
-0.8 to 0.8 front
-2 to -0.5 rear
Toe
-0.12 to 0.12 front
-0.04 to 0.2 rear
Caster
5.2 to 6.7 front
Spirited/Street (or mildly prepped autox/track car on tires higher than 200tw)
Camber
-2 front
-1.5 rear
Toe
Zero all around
Auto-x
Camber
-2.5 to -3+ front
-2 to -3 rear
Toe
0.0 to -.08 front (toe out)
0.0 to .08 rear (toe in)
Track
Camber
Close to max or max in front
-.05 less than the front in rear
Toe
0.0 front
This was copy/pasted from someone else who posted it on the forum, I would give credit but I no longer remember who posted it.
Trueweltall is offline   Reply With Quote
Old 08-21-2021, 07:42 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
I'd change in this only front camber for "track". It usually is tires-track specific. And often it's not "max", closer to auto-x's front camber. "close to max", as in -4dg and more camber, is more .. hmm .. for drifting?
Old 08-22-2021, 09:55 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
You're right that it's somewhat tire-specific in that some tires can tolerate less, but generally these cars want a lot of front camber at the track.
FWIW I'm running max front camber I can get with camber plates, -3.5 left, -3.9 right, for most tracks. I might dial back right-side to even it up at -3.5 for Watkins Glen next month...
For spirited street, I'd go with max camber from crash bolts and offset upper mounts up front should be -2ish, and whatever natural camber from running lower than stock at rear, should be around -2.5 ish...
Old 08-22-2021, 04:12 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
ZDan: oh, you are running asymmetrical alignment? interesting. Any more details of specific of such? Probably i'll never use such, as visiting different tracks, and also DD mine, and redoing alignment twice per year ("winter" & "summer/track" ones) not per track, but still seems interesting topic to find out more about..
Old 08-22-2021, 04:36 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Only because maxed out, that's where they land. A bit more on the front right. New Hampshire is CCW, so that's outside front. Palmer CW Turn 4 is a left-hander that is *murder* if you have any understeer at all, so keeping front right maxed there made sense. See how it goes at Watkins Glen (CW), if no understeer in the left-handers like Turn 9 I might dial right front camber down to -3.5...
Old 08-22-2021, 05:55 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
ZDan: but isn't some understeer beneficial in some cases, as in extra stability accelerating out? Obviously that much as in OE alignment seems way too much, one needs to work against it a lot, but imho slight understeer biased alignment that can be easily controlled with throttle lift-off or slight braking induced mass transfer to easily switch between over- and under-steer, as needed, shouldn't be evil?
Old 08-22-2021, 09:19 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yes! Which is why I'll wait until I see how handling is at WGI before i make any changes.
That said, *in general*, for stockish cars, *with* decent camber, handling is not too too terribly dependant on camber. -3.5 ish seems to be the place to be...
Contrary to popular theologics, evil is good. More oversteer, less understeer. Have fun!
SOLD: Raceseng caster + camber - adjustable front camber plates higrip Brakes, Suspension, Chassis 4 09-17-2019 01:43 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 05:03 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
