Old 08-11-2021, 07:54 AM   #1
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
Tech Spec diff between Whiteline front end link KLC 219 vs 179
Hi Guys!!! I would like to ask about tech specification and performance differences between front end link KLC 219 and KLC 179 for Subaru BRZ 13-19, because in the whiteline performance site mentions boths end links are for the same model subaru BRZ, but the original manufacturer end link is longer compare with the KLC 219.
FRONT END LINK KLC 219
FORNT END LINK KLC 179
AEBRacing is offline   Reply With Quote
Old 08-14-2021, 09:56 PM   #2
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Lowered versus not lowered?
jeepmor is offline   Reply With Quote
Old 08-18-2021, 10:09 AM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Correct! Even if you lower just half an inch you'll want to go with the shorter end link so it doesn't bash into your inner fender on compression.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
jeepmor (08-22-2021)
Old 09-12-2021, 09:29 PM   #4
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
In order to close this post, Whiteline guys answered me the difference between the short and long end link is the KLC 219 is applicable only for the whiteline sway bar, not fit in other sway bar, the long end link KLC 179 is applicable for OEM sway bar, the problem is in its web page nothing say about that
DIY: Whiteline Front End Link Install thekevinvo DIY (Do-It-Yourself) Guides 0 09-08-2020 04:30 PM
Whiteline Diff outrigger, Superpro full subframe and front LCA anti-divebushings in_sherman Brakes, Suspension, Chassis 2 08-24-2020 03:35 PM
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? mistople Engine, Exhaust, Transmission 10 09-21-2018 06:01 PM
RCE Tarmac 2's, Swift springs, Whiteline front end-links, Blitz Nur-Spec exhaust justinco Brakes, Suspension, Chassis 4 12-17-2017 06:57 PM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
