Old 08-11-2021, 05:48 AM   #1
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Nut for 12mm brake line bolt
The 12 mm bolt that holds the brake line to the front strut is somehow constantly spinning and doesn't torque down, is there any problem with just installing a nut on the other end of it to secure it? And what size and pitch will it be? I must've over tightened
Jajanken86 is offline   Reply With Quote
Old 08-11-2021, 06:11 AM   #2
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
After following a trail of Subaru part numbers, can anyone confirm if m10x1.25 will work fine? Flange nut or just non-flange standard hex?
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings fc3s_johnny Brakes, Suspension, Chassis 11 10-05-2020 10:26 AM
How to line up banjo bolt with spiegler. pher.da.rico Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 09-22-2020 09:46 PM
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
Brake line degradation so26 Issues | Warranty | Recalls / TSB 8 05-14-2013 08:47 PM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
