Old 09-22-2020, 02:49 PM   #1
pher.da.rico
Drives: 2018 Premium Black silica BRZ
How to line up banjo bolt with spiegler.
Hey how is everyone doing! I was really hoping to get some help on how to line up the banjo bolt properly to my Spiegler in order to reinstall my brake calipers.
I keep trying to tighten it but it’s fails to line up with the spiegler.
pher.da.rico is offline   Reply With Quote
Old 09-22-2020, 03:25 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Do you mean you're having issues lining up the brake hose? I haven't looked at the hoses for this car, but isn't there an alignment pin on the hose end that fits into a slot on the caliper?
dragoontwo is offline   Reply With Quote
Old 09-22-2020, 03:27 PM   #3
pher.da.rico
@dragoontwo
Old 09-22-2020, 04:45 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by pher.da.rico View Post
@dragoontwo
Is that really something you need to do? It's a hydraulic system so fluid pressure should go around corners pretty easily.
Spuds is online now   Reply With Quote
Old 09-22-2020, 04:50 PM   #5
pher.da.rico
Is that really something you need to do? It's a hydrologic system so fluid pressure should go around corners pretty easily.
I was told I didn’t have to, but I didn’t wanna be careless about it. So I wanted some more reassurance.
Old 09-22-2020, 05:00 PM   #6
ls1ac
ls1ac's Avatar
The banjo head is designed so the fluid moves around the bolt, meaning bolt position is not of consequence.
The Following 4 Users Say Thank You to ls1ac For This Useful Post:
NoHaveMSG (09-22-2020), pher.da.rico (09-22-2020), soundman98 (09-22-2020), Spuds (09-22-2020)
Old 09-22-2020, 05:37 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
the trick is to never tell the fluid!
Old 09-22-2020, 09:46 PM   #8
dragoontwo
dragoontwo's Avatar
Sorry I didn't make it back sooner, but it looks like everyone covered it. It doesn't need to be lined up. The fluid doesn't care.
The Following User Says Thank You to dragoontwo For This Useful Post:
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
Spiegler brake lines (front and rear) peaches Brakes, Suspension, Chassis 2 08-06-2019 08:53 AM
Rotrex C38 Compressor Banjo Bolts itsbenlol Forced Induction 2 09-04-2018 11:23 PM
Rear brake caliper banjo bolt size? ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-22-2016 06:51 PM
FS: Spiegler SS lines front and rear ayau Brakes, Suspension, Chassis 2 12-29-2013 02:33 AM
