Old 08-03-2021, 05:31 PM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
How long do you go before changing brake fluid
I’m only doing HPDE and the like and I’m on my 3rd day so far with RBF660 (in a car that was brand new to start with) so how often do you guys change yours? Just when it starts to turn dark or do you have an interval?
Jstyle is offline   Reply With Quote
Old 08-03-2021, 05:45 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
I get three 2-day events out of regular off-the-shelf parts store DOT4 or DOT5.1 full flush at beginning of season, then I'll do a caliper-bleed and that takes me another three events (usually ending my season). I do have the big Brembo brakes though...
I bet you don't need RBF660. I've never had issues with "normal" DOT4/DOT5.1 even in the 550hp FD RX-7.
Jstyle (08-04-2021)
Old 08-03-2021, 07:08 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine starts to darken at about 5-6 track days. I change it once a year regardless.
NoHaveMSG is online now   Reply With Quote
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Jstyle (08-04-2021)
Old 08-03-2021, 07:16 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I do about 6 track days a year so yearly with Motul 660
The Following User Says Thank You to TommyW For This Useful Post:
Jstyle (08-04-2021)
Old 08-04-2021, 07:04 AM   #5
Jstyle
Jstyle's Avatar
Drives: 2020 86
I do drive it to the grocery store every now and then but largely speaking my miles are to the track on the track and from the track. I’ll probably do 5-6 track days this year so I’ll see how it looks at the end. Thanks guys!
Old 08-04-2021, 07:09 AM   #6
Petah78
Drives: 2022 BRZ sport-tech
For a car that sees track time, once at the beginning of the season. Brake fluid picks up moisture relatively quickly thus lowering it's boiling point. I usually change it out along with the clutch fluid every spring.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 08-04-2021, 05:53 PM   #7
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
For autocross (~20 events/year and 400 runs) I bleed about twice a year. Pads and rotors once every two years. But I also DD the car and drive it to/from Lincoln and California (from Seattle) so it's getting 20,000 miles/year of driving.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Squishy brake pedal after bleeding and changing fluid JaeMHC Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-05-2020 08:35 PM
Squishy brake pedal after bleeding and changing fluid JaeMHC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-03-2020 08:38 PM
How long to wait before changing MT fluid? mistople Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 42 03-01-2018 04:45 AM
FRS Fluid Changing (Beginner) SmireyFase Engine, Exhaust, Transmission 10 06-27-2016 03:07 AM
Using higher quality brake fluid vs using cheap but changing more often ayau Tracking / Autocross / HPDE / Drifting 41 06-14-2015 01:20 PM
