Drives: '16 FRS-MT Ablaze Red
Replace Flywheel Bolts
Hi
I'm preparing to install a southbend stage 3 daily clutch with oem flywheel for an upcoming turbo build. Would you recommend replacing the flywheel bolts? Or is re using the oem bolts okay? Thanks |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#3 | |
Drives: BLue 2013 frs
ARP flywheel bolts. you can re use them. |
not playing cards
| replace flywheel? | Jeong | Engine, Exhaust, Transmission | 41 | 05-19-2022 12:08 PM |
| Camber bolts or crash bolts for max spring perch clearance? | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-29-2021 12:53 PM |
| Bad ball joint;possible to just replace balljoint or do I have to replace control arm | kev0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-03-2019 04:07 PM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 03:26 PM |
| replace front crash bolts to add camber? | Matt Andrews | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 06-15-2012 11:05 AM |
