Old 07-21-2021, 09:06 PM   #1
Darknd666
Drives: 2017 86
Flexible ABS lines for relocation
I want to relocate the ABS, but need flexible hydraulic lines. On the other hand removal is done with a kit and creates a knob for adjusting rear front brake pressure. If I were to remove the ABS and KEEP the brake booster would the CEL come on for the ABS or can ECUtek mod the ECU ROM to disreguard the ABS? I have converted a 02 Galant from automatic to manual before and paid a programmer to remove the Automatic solenoids from the ROM so I know this is a thing, but is it possible with this platforms computer?
EDIT: Another Thought, if I could get the sizes for the fittings on the ABS(VSC,VDC) module i could just make my own fittings and put it somewhere else in the engine bay?
My purpose you ask? The ABS is just in the way, I want a bigger air filter for my JDL turbo or at least more space so it doesnt rub against anything.
Darknd666 is offline   Reply With Quote
Old 07-21-2021, 09:39 PM   #2
Ashikabi
Ashikabi's Avatar
You can bend and flare new brake lines. Or adapt them all to AN
The Following User Says Thank You to Ashikabi For This Useful Post:
NoHaveMSG (07-22-2021)
WTB: STi Flexible V-Bars N_Raged Want-To-Buy Requests 2 06-11-2020 11:10 PM
FS (Chicago) - Winmax W5 Rear Pads, Spiegler Front Brake Lines, Stoptech Rear Lines Jamestl Brakes, Suspension, Chassis 4 01-10-2020 05:41 PM
FS: OEM STI Flexible V-Bars Ethereal05 Brakes, Suspension, Chassis 2 01-15-2018 03:19 PM
Flexible Draw Stiffener and Flexible Tower Bar Maxwell BRZ First-Gen (2012+) — General Topics 5 01-11-2015 11:43 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
