Hi.
Drives: 14' Asphalt
Clutch softer/lighter then normal
Hello all..been a while.
TOB has been goin out on my 14' FRS for past 20k miles. Last week I was driving then the clutch got super soft...knew immediately something was wrong. Drove home. Well it's time to do it. 117k miles. Anyways got trans out...sure enough TOB seperated like most others. I ordered TOB, clips, spring, fork, pivot support and bearing retainer from dealership(Wed)..didn't get trans out till Thurs so didn't know what parts I needed. Clutch disk looked fine. Pressure plate looked fine. Fingers didn't have excessive wear. Verified torque and said i'm gonna run with this clutch.... I ended up only using TOB, clips, and spring. Fork, pivot ball and bearing retainer had minimal wear. Fork no cracks or bends. Tips minimal wear. So I put it all back together greased up, torqued up, fresh fluid in trans and got it on ground. Start it up..no more squeeling or grinding from TOB but clutch still feels incredibly light. I read tons of threads on here. Everything points to slave cylinder and needing a fluid change on hydraulic system after reading 4 or 5 threads on here. I did notice a bit of wetness out of boot of slave....but not loosing fluid out of reservoir(yet). Fluid is pretty dark..doesnt smell burnt though. The issue though that makes me come on here and ask is that I can get car into gears fine and drive it fine....just clutch feels lighter then normal. I believe there is air seeping into clutch hydraulic system. Any input? Don't know the platform that well even though I've had the car for 106k miles lol. So much mixed opinions and regards on these clutches in general.
14' ZN6
92' RN80 81' RN38 "Shitbox" I like Toyota's IG: undefindedt Last edited by undefindedt; 07-13-2021 at 06:50 PM. |
So bleed the clutch slave
Sent from my ONEPLUS A5010 using Tapatalk |
not playing cards
If the clutch works properly, you probably got used to the dry, sticky fork.
Normal clutch is suuuuuper light when it's working properly. Like stupid light.
#4 | |
Hi.
Drives: 14' Asphalt
Thanks for assurance everyone
14' ZN6
92' RN80 81' RN38 "Shitbox" I like Toyota's IG: undefindedt |
| Does Clutch Wear Look Normal? | Jamestl | Engine, Exhaust, Transmission | 6 | 02-04-2019 06:50 PM |
| Is there any way to make steering wheel lighter(softer)? | kdyg123456 | Scion FR-S / Toyota 86 GT86 General Forum | 86 | 02-03-2018 03:34 PM |
| This normal sound for clutch on all twins? | Packofcrows | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-02-2015 12:01 AM |
| Clutch release sound...is this normal? | Decimus | Southern California | 0 | 06-20-2015 12:23 PM |
| clutch/gear box getting softer | zERoTu | Issues | Warranty | Recalls / TSB | 3 | 06-05-2014 08:18 AM |
