Old 07-13-2021, 04:29 AM   #1
headfake
Drives: 2016 Scion FR-S
OBD code P0852 "park/neutral switch high"
Hi,
I have a 2016 Scion FR-S, stock, manual transmission. It has a P0852 OBD code ("park/neutral switch high") that's blocking me from getting an emissions test (it comes back on if you clear it).
I guess it has something to do with detecting the position of the shift lever; I also noticed:
  • rear view camera does not turn on in reverse (used to work)
  • the gear indicator that you can turn on on the dash doesn't show up (only shows the up arrow for the fuel economy shifting)
I can see on the OBD scanner that the clutch position sensor still works, and it does require you to push in the clutch to start it. There are also "reverse" and "neutral" switches that you can see on the OBD and neither of them ever change.
Is there any chance there's just some loose connection I could easily find? Or should I just take it to the dealer?
Thanks for any help
headfake is offline   Reply With Quote
Old 07-13-2021, 07:42 AM   #2
It is your neutral switch then.
Here is the repair manual.
https://gt86stuff.onrender.com/t3Portal/
Just follow the tree until you get to the switch repair.
New paint code for 2018? "Thunder" sirsol66 Scion FR-S / Toyota 86 GT86 General Forum 76 10-05-2017 01:21 AM
Diode Dynamics Sale: Happy 4th! 20% OFF LEDs with code "JULY4" Diode Dynamics Announcements, Contests, Giveaways 1 07-03-2017 11:27 AM
Diode Dynamics Sale: Happy 4th! 20% OFF LEDs with code "JULY4" Diode Dynamics Announcements, Contests, Giveaways 0 07-01-2016 03:06 PM
Help Installing "Kill Switch" carma143 Electronics | Audio | NAV | Infotainment 15 09-13-2015 10:44 PM
Red Hex Color code # for "86 logo" Lokki Scion FR-S / Toyota 86 GT86 General Forum 2 09-16-2013 08:47 AM
