Old 07-12-2021, 01:33 PM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
Question Gas pedal became less sensitive over time after purchasing brand new
I drive a 2016 Manual Scion FRS. I purchased the car brand new and I've noticed that when I first started driving the car, the gas pedal was extremely sensitive and responsive to my inputs. But since then, slowly over time through the course of driving normally, I've noticed that the gas pedal became less sensitive and responsive to my inputs.
It still works normally, but the difference is that it takes a longer distance when stepping down on the gas to reach the same RPM's compared to when the car was fresh and brand new. What is happening here? and how can it be fixed to be more sensitive and sharp as it was when brand new?
ghostzfh is offline   Reply With Quote
Old 07-12-2021, 02:41 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Could be the ECU learning and adjusting the throttle due to how you drive?
If you flash your car with a tune, you can usually select an option for a more sensitive peddle.
MS, CSCS, TSAC-F, CPT
Old 07-12-2021, 09:35 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
What fuel do you use? It could be that you are getting knock so the ECU has learnt to pull timing, making the car feel more sluggish.
1974 TA22 Celica
2013 86 GT
Old 07-12-2021, 10:02 PM   #4
ghostzfh
I use 93...just normal gas... So far I haven't experienced knock.
Old 07-12-2021, 10:19 PM   #5
Lantanafrs2
Drives: 2013 frs red
I would try a battery reset
Old 07-13-2021, 07:39 AM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
You wouldn't know if the engine had slight knock that caused the ecu to pull timing.
Old 07-13-2021, 03:36 PM   #7
jflogerzi
jflogerzi's Avatar
Be aware if you pull the battery the ECU will reset the throttle so it will feel dull for about 15-20 miles.
2013 Series 10 FRS #553
Old 07-13-2021, 06:16 PM   #8
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
You can also try to just relearn the tps. Whenever you flash the ecu the pedal does feel dull but if you do the relearn it gets rid of the wait for it to sharpen back up. Don't quote me but if I remember correctly you turn the car on but don't start it and then smoothly depress the pedal all the way down and smoothly back up a bunch of times. I've seen any where from 5 times to 20 so I usually just do the 20 and since I'm me I do it a second time as well. Then just start the car as normal and enjoy.
aKaGorganZola is offline   Reply With Quote
Old 07-13-2021, 10:46 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
maybe you've changed as a driver?
go rent a camry for a weekend.
Old 07-14-2021, 12:47 AM   #10
humfrz
Bubba says, it's hotter outside - all cars are running sluggish. Come fall, it will be OK.
Old 07-14-2021, 12:52 PM   #11
jflogerzi
jflogerzi's Avatar
Not if your running upgrading cooling and e85 blend
Old 07-14-2021, 02:13 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Upgraded cooling will help with engine to not overheat. It won't affect temp of ambient air and thus air density, which in turn means how much oxigen get's into cylinders, just like height above sea level. Unless you count under upgraded cooling intercoolers for forced induction setups.
Old 07-14-2021, 03:31 PM   #13
humfrz
don't argue with Bubba, in his world, he ain't never been wrong -
Old 07-14-2021, 03:42 PM   #14
ghostzfh
Where do I start with flashing? I keep hearing about Ecutek and OFT. I'm kind of new to that stuff. How do I know which tune to flash to get a linear 1:1 pedal response?
gas pedal, sensitivity, wear
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 04:12 PM
Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. captain awesome Interior Parts (Incl. Lighting) 2 04-21-2021 10:56 AM
FS: BRAND NEW Verus Throttle Spacer + Cusco Accelerator Pedal BRZ8844 Canada Classifieds 1 12-04-2020 01:43 PM
first time running Slick tires... Pedal dance or normal 5sec trac off? dejxx Tracking / Autocross / HPDE / Drifting 6 11-16-2014 04:07 PM
Long time lurker, brand new owner SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 26 09-24-2013 07:43 PM
