Old 07-08-2021, 12:43 PM   #1
suppjc
Drives: 2015 Scion FR-S Firestorm
Dusty fusebox
I happened to open the fusebox in the engine bay and found it was little bit dusty. I’ve looked up if there were any other people experiencing the same, but I don’t see many posts mentioning this.
I know it’s not alarming as is, but makes me wonder if I’m missing a rubber seal or something. Given the car is about 6 yrs old, it’s not too bad, but any idea I can clean it safely, preferably without disconnecting the battery?
suppjc is offline   Reply With Quote
Old 07-08-2021, 01:09 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
A clean paint brush and/or compressed air
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
suppjc (07-08-2021)
Old 07-08-2021, 03:05 PM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Dusty Fusebox......
Great porn name.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 5 Users Say Thank You to FR-S2GT86 For This Useful Post:
Capt Spaulding (07-09-2021), Cephas (07-22-2021), NoHaveMSG (07-08-2021), Overdrive (07-08-2021), suppjc (07-08-2021)
Old 07-08-2021, 10:33 PM   #4
suppjc
I was thinking of a paint brush too since I have one, but just worried about the static electricity it might cause. I'm maybe too cautious?
Thank you.
Old 07-08-2021, 10:38 PM   #5
suppjc
Originally Posted by FR-S2GT86 View Post
Dusty Fusebox......
Great porn name.
F: "Let me take yours off and blow it and clean it myself"
Whatever that might mean
The Following User Says Thank You to suppjc For This Useful Post:
Ultramaroon (07-09-2021)
Old 07-08-2021, 11:14 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Thank you.
Would pair nicely with a can of dust-off. No worries about static. There is no dust in the important parts, the connectors underneath each component. After you've dusted it, pull one of the components. Doesn't matter which. You'll see what i mean.
No need to disconnect the battery.
suppjc (07-09-2021)
Old 07-09-2021, 12:26 AM   #7
suppjc
Ah yes, a dust off will be nice! Will do!
Old 07-09-2021, 12:49 AM   #8
Ultramaroon
not playing cards
Dust-off + paint brush = profit
Old 07-21-2021, 04:56 PM   #9
I opened up my box to steal the spare 15amp and was appalled to see the crap in there! I was too shocked to take a picture but let's just say the OP's is spotless compared to what I found. Since I don't believe a fuse block is a great place to build sand castles I am going to see if I can find some thin foam weather-stripping to put between the top and the base. I do not want to even imagine the results if I got any dampness up in with all that sand and dust.
bcj (07-21-2021)
Old 07-21-2021, 08:46 PM   #10
QHawk
QHawk's Avatar
Drives: 2020 86GT
DustOff? To blow everything even deeper into every recess? This is a job for a brush and vacuum cleaner.
QHawk is offline   Reply With Quote
The Following User Says Thank You to QHawk For This Useful Post:
Tcoat (07-22-2021)
Old 07-21-2021, 09:05 PM   #11
Ultramaroon
not playing cards
meh
Old 07-22-2021, 07:05 AM   #12
meh
Q is right. I wish I had the presence of mind to take a picture but I screwed up and forgot. You really needed to see it to believe it.
The location of the fuse box means that not only was it filled up with dust but also actual sand get's pushed up in there. This may not be an issue for cars that are only summer driven or where they don't sand and salt roads but for many of us the potential of forcing that dust/sand/salt even deeper with Dustoff is just asking for trouble down the road.
I used a shopvac with a brush attachment and that got it cleaned up like new and didn't push everything down under the fuses and relays. I actually pulled a couple to check.
Simulation of my cleaning it
bcj (07-22-2021)
Old 07-22-2021, 11:35 AM   #13
Ultramaroon
not playing cards
What isn't seen is that the bottom of that box is all open. Nothing magical going on below the surface. Big fat wire bundle with bare terminals clipping into the receptacles. You could blast it with a hose to clean it.
Old 07-22-2021, 11:46 AM   #14
I am more concerned about the crap that was down between the prongs of each fuse and relay.
tcoat's dusty box
Dusty fuse box msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 07-26-2019 01:09 PM
Interior fusebox - can someone confirm? 1Cor10:23 DIY (Do-It-Yourself) Guides 6 04-16-2015 07:10 PM
Super dusty pads. HELP!!! omegared19 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-12-2014 01:04 AM
BRZ Fusebox BRZfan BRZ First-Gen (2012+) — General Topics 0 10-17-2013 07:44 PM
WTB: ABS, Fusebox, AC condenser mariolefty1 Engine, Exhaust, Bolt-Ons 0 05-06-2013 04:46 PM
