Old 10-17-2013, 07:44 PM   #1
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
BRZ Fusebox
Just a Head's Up:
If you ever have to replace a fuse at the fuse box located beneath the steering wheel - be prepared. You will need a flashlight or other light source and a very flexible body.
I used a portable "mini-pump" for tire pressure and blew the 15 amp fuse controlling one of the 12 volt power outlets.
Be sure to follow the directions for using the 'mini-pump'. I connected to the tire valve BEFORE turning on the pump.
BRZfan is offline   Reply With Quote
WTB: ABS, Fusebox, AC condenser mariolefty1 Engine, Exhaust, Bolt-Ons 0 05-06-2013 04:46 PM
