| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: 2013 scion frs
crank no starting, no rpm signal
I have a 2013 scion frs m/t i had a spun bearing and I replace the short block with a new one but now only crank but no start and when I use my scanner too see what is going on I see I don't have a crank or rpm signal I change the sensor check the harness and check the plate all that is good but it won't get any rpm signal, but also if I spray start fluid will start idle really rough for less Then 5 second and died I don't know what exactly anyone know or maybe someone the run to this same problem what may be.
Drives: 2022 GR86
Wrong subforum?
| BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD | MJones_RB | Engine, Exhaust, Bolt-Ons | 3 | 03-31-2021 03:07 AM |
| Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 05:57 AM |
| [GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt | reeves | Engine, Exhaust, Bolt-Ons | 0 | 08-22-2018 07:01 PM |
| starting out | dmitri93 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-11-2014 12:06 AM |
| Rev when starting ? (Possible and why ?) | Simon99 | Software Tuning | 11 | 05-22-2014 04:12 AM |
