Old 07-07-2021, 04:50 AM   #1
86cruzing
Drives: 2016 Frs
Question Spare tire question
So I converted my PCD from stock wheels 5x100 to 18’s 5x114.3
Do I need to get a specific spare tire or anything that’s basically 18 with my new bolt pattern? I’m confused on where to find a spare tire.
86cruzing is offline   Reply With Quote
Old 07-07-2021, 07:19 AM   #2
Ashikabi
Ashikabi's Avatar
Get one from a junkyard. You have to research what vehicle/s can came with a spare in the size you want though. Junkyard guys won't know.
Old 07-07-2021, 05:21 PM   #3
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
I believe most 5-lug Hondas and Toyotas (non-FRS/86) use 5x114.3 if that helps you.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 07-26-2021, 08:48 AM   #4
halfwaytobedlam
Drives: 2014 Toyota 86 GTS
Maybe subaru wrx? I think some of them use 5x114.3 and the offset might be better. Make sure it doesnt rub tho.
halfwaytobedlam is offline   Reply With Quote
Old 07-26-2021, 09:57 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Getting one from latest gen WRX is your best bet. Maybe even the STI. Usually no problem unless you have a big brake kit to contend with.
EndlessAzure is offline   Reply With Quote
Old 07-30-2021, 05:56 AM   #6
86cruzing
Drives: 2016 Frs
Interesting I’ll have to check that out ty.
Old 07-30-2021, 05:59 AM   #7
86cruzing
Drives: 2016 Frs
I Actually have a 4 pot caliper from a 2007 wrx but I think I should be okay.
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 09:36 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Spare tire ??? Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-28-2014 06:46 PM
Spare tire question Raven23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-28-2013 10:23 AM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
