Old 07-03-2021, 11:50 AM   #1
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Question Going up a tire size
Hey guys! I’m new to this forum and to cars as well (just got my brz back in january).
I have a question about going up a tire size/width. As you know, the stock tire dimensions are 215/45/17. I’m planning on sticking with 17in rims, but want to know if there will be any issues if i go up to 225/45/17.
What are the pros and cons? And will it throw off my speedometer?
Sorry if these are dumb questions, I’m such a newb lmao but I want to learn the most that I can! Any and all feedback will be much appreciated!
julzbrz is offline   Reply With Quote
Old 07-03-2021, 12:10 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
225/45/17 is fairly common to use. Your speedo will read lower then you are actually going.
Old 07-03-2021, 12:44 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
per wheel-it-fit.com, changing to a 225/45/17 means the tire diameter will increase from 625mm to 634mm, which would result in a speedo difference of -1.4km/h, which simply means at 60mph, the car will read about 0.5mph slower than actual.
which, my car and others in my families fleet consistently measures around 2mph slower according to speed signs anyways.
Old 07-03-2021, 12:50 PM   #4
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Talking
idk if im replying to this right but is there anyway to fix that or is it just something you gotta deal with? thank you for your reply!
Old 07-03-2021, 12:52 PM   #5
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Smile
thank you so much for the reply! i will take that into consideration. a wider tire is grippier correct ?
Old 07-03-2021, 02:24 PM   #6
Grady
Grady's Avatar
EcuTec can and I believe OFT will also. I have that tire size and a there is about a 1 to 2 MPH difference between Speedo and GPS at 70mph.
Old 07-03-2021, 03:55 PM   #7
soundman98
soundman98's Avatar
Tire compounds are like girlfriends. And try to say that any one of them are better based only on size!
Tire compound grip is more based on other factors in the rubber and tread. Yes, there's going to be a slightly larger contact patch, but 10mm extra width isn't going to have a significant difference either way. I doubt one could even get much different in track times with that change. Might be good for 1/10 of a second at best
Old 07-04-2021, 01:45 PM   #8
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
that’s not bad honestly, and seems like something i could deal with😂
Old 07-04-2021, 01:46 PM   #9
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Talking
i like that analogy
thanks for the helpful info! everyone on this forum seems so nice
Old 07-04-2021, 04:16 PM   #10
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
With a new set of Continental ExtremeContact 225/45-R17s my speedometer was right on the money (speedo gets more optimistic as tires wear). Manufacturers almost always calibrate speedometers to be 1-2 mph optimistic at 60mph to make sure they aren't responsible for you go over the speed limit.
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
thomasmryan (07-08-2021)
Old 07-10-2021, 06:49 PM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
On 7" wheels the 225 may be slightly pinched and as a result be a wee bit squishier on turn in. It may also ride a little smoother.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-12-2021, 11:46 AM   #12
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
If it’s just for DD, keep stock size for light weight and playfulness.
Ernest72 is offline   Reply With Quote
Need some help with what tire size i should get. sosky9 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-27-2018 04:20 PM
Tire rack giving me a hard time on tire size, so please help! NOI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-03-2017 06:27 PM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
