Old 02-24-2018, 07:28 AM   #1
sosky9
Drives: 2017 Subaru Brz
Need some help with what tire size i should get.
So i’m a new owner of a 17 Brz and i’m going to get some new wheels but not to sure what size tires would fit. Ill be getting some cosmis mr7 18 x 9 +25. Note i still have stock suspension. Thanks for the help.
sosky9 is offline   Reply With Quote
Old 02-24-2018, 11:17 AM   #2
swarb
245/35
+25 is going to poke outside the fenders about an inch on stock suspension/camber.
Old 02-25-2018, 09:59 PM   #3
Zentec
Drives: 2017 Toyota 86
I stayed with the stock 17wheel. I did change my tires though. I went with the 225 45 17 continental extream contact dw. They are an awesome tire. The main reason I stayed with the 17s so I could maintain the ratio and not loose any power. When you go bigger and out side the ratio you loose power and effency. The type of tire rubber and style matters more than size. In the future I may change to a lighter wheel but I will stay with the stock size. These cars handle extreamly well so I will not mess with the supession plus as it is now I don’t scrape of curbs or parking stops. I do recommend to put nitrogen in them as it’s better for the tires and mpg and it will maintain tire psi.
Zentec is offline   Reply With Quote
Old 02-27-2018, 04:20 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the forum.
Read through this thread
http://www.ft86club.com/forums/showthread.php?t=37848
It looks like all these guys are running 225/40's, on wheels of the same spec, to get them to "fit."
I LIKE TIRES!
brz, wheels and tires
Tire rack giving me a hard time on tire size, so please help! NOI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-03-2017 06:27 PM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 12:03 AM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
