| Member's Car Journals Car journals by our members. |
Drives: GT86 '13
The Swedish trackday 86
Hi folks.
I've been lurking here for a while now and figured it's time to make an appearance. I drive a 2013 GT86 (Yes, not an FR-S) since a little while back, in pursuit of a better track experience. My name is Jonathan and I live in Stockholm, Sweden, where it's 3 hours to the nearest proper track. ![]() EDIT: I'll add a list of the stuff I've put on here: - Öhlins R&T w/ 80N/mm springs - Essex AP Sprint 299mm BBK front - Stainless steel brake lines f & r - Raceseng CasCam plates front - HKS EL header - HKS Hi-Power Spec L catback - HKS Airfilter - HKS Oil cooler - HKS GT2 supercharger (w/ 41mm restrictor) - Deuschwerks 65cc fuelpump - Beatrush master cylinder brace - Ecutech custom tune Also running Nankang AR-1 tyres in 245/40r17 on JR SL01 alloys, and PFC-01 brake pads. A few years ago I bought my first proper sportscar (or well, GT-car): ![]() I drove this for a year, went down to Croatia (7000km roundtrip) and eventually actually went around the track with it. Naturally, it's well balanced with a fantastic engine, but it's proper heavy. Torque converter auto doesn't add to the racing feel and the fear of getting damage deducts from the fun factor. Thus I now have a more reasonable daily (bmw 325i e91) and a track toy. ![]() So since everyone who has a toyobaru ft86something loves modifying it, here's what I've been doing ![]() I started with the headers, to get a little boost in power. I went for equal length ones since I further down the line planned on boosting it and thought that unequal load on the cylinders would be a bad idea. I miss the subaru rumble but that's not the purpose of the car. Or so I tell myself. Good long day in the sun with some friends resulted in HKS EL headers being mounted, along with an EcuTek remap for some torque dip removal: ![]() I'm trying to get these guys to track their cars as well.. New headers look amazing compared to the old catted stock system! ![]() Not that I'll ever see them ![]() Next up, I swapped the springs for.. well pretty much tein-coloured stock springs. Mistake, I must admit, to not research properly and just trust the shop. ![]() ![]() Doing this in my company parking garage is not ideal, but I had good company (the guy miata owner from before). After bringing the car to the track I also noticed that I couldn't quite hear the engine properly, so I had to look at the tachometer way too often. HKS Hi-power spec L exhaust did a good job eliminating that issue (the drone around 3k is awful): ![]() After my next proper trackday I found the limit of my stock brakes and pads (no surprise there, just hoped it'd be a little further off). I got to ride along in a TRD'ish friend with the Essex AP sprint kit and some proper tyres, and man what an experience. Safe to say, I ordered the same kit from CSG a few days ago. ![]() I've also got some new lighter and wider alloys to house my 'r-tyres' (Nankang AR-1 245/40r17), coilovers from Öhlins (supporting the local industry) and another lapse of idiocy that I'll post about in the days to come. Last edited by Cressell; 09-13-2021 at 04:22 PM. |
Drives: GT86 '13
Next level idiocy:
![]() Dyno graph to come. I've installed an HKS oilcooler, DW65 fuelpump and a HKS GT2 (v2) supercharger kit with a 41mm restrictor. Last edited by Cressell; 07-02-2021 at 12:42 AM. |
Drives: Transit Campervan / Turbo GT86
Hello Cressell, nice toy there!
I like the "roadkill" style installation there... ![]() Will you be running e85 or petrol? |
#4 | |
Drives: GT86 '13
![]() Petrol for now, the fuel quality here is good so I'm in the 300-310whp range with the 41mm restrictor. Also, any more power and I'll be too scared for my rods to drive it properly - my next project will be to build an engine suitable for more power. |
Drives: GT86 '13
![]() Next thing to add. |
damn going for broke!! BTW take a look at this thread might help with the drone
They are STI hangers and alot ppl are having good results reducing drone: https://www.ft86club.com/forums/showthread.php?t=143514
2013 Series 10 FRS #553
#7 | |
Drives: GT86 '13
This also came through:
Drives: GT86 '13
![]() These need installing asap! |
#9 | |
Drives: GT86 '13
Thanks again.
#10 |
Howdy
Drives: 2020 BRZ PP
Looks good! Keep us updated.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#11 |
Drives: GT86 '13
Thanks! Glad to see someone actually reading this
![]() Brakes are now installed, with new pads all around (PFC-01) and proper brake lines in the rear as well. Flushed with new brake fluid and added a master cylinder brace - pedal feel is good but the brakes won't feel grippy until I've done the bed-in procedure properly. ![]() ![]() ![]() ![]() Actually think it looks quite alright! Upon installing the coilovers I ended up 29mm down in the front, 25mm in the rear. No camber rear, and a whopping 0,7 deg POSITIVE camber up front. Result: ![]() Safe to say, I've ordered camber plates to get myself a nice -2,5 degrees or so in the front, and camber bolts for some -1,5 deg in the rear.
#12 | |
#13 | |
Drives: GT86 '13
It's strange though - I thought having lowered 25mm that I should definitely have some negative camber. |
#14 | |
| SQD's Swedish '13 GT86 | sqd | Member's Car Journals | 34 | 04-02-2019 07:16 AM |
| Sleepy Piston's road & track 86 (Swedish time attack) | Sleepypistonracing | Member's Car Journals | 79 | 08-09-2017 04:03 AM |
| Toyota GT86 2013. Swedish Time attack 2015 | Fricke | Member's Car Journals | 25 | 02-05-2016 03:31 AM |
| Trackday at ORP | jblmr2 | Northwest | 6 | 02-21-2014 05:30 PM |
| Swedish GT 86 joins the CEL club. My 86 infact. | beardy | EUROPE | 1 | 12-05-2012 07:37 AM |
