Old 06-29-2021, 11:59 AM   #1
brad.boyer
Drives: 2013 Subaru BRZ
Unhappy 2013 BRZ Transmission Troubles
Good morning everyone.
I am having troubles with my stock manual transmission. When I coast while in gear I can hear a rubbing/grinding sound and a whine sound when accelerating. I can't figure out what is going on. My BRZ is my daily so I can't just pull the transmission out. Does anyone have any idea what might be going on?
I tested the synchros by no clutch shifting. They seem to be in alright condition. I know I need to replace the TOB but I don't believe that is what is causing the noises I am hearing. I just replaced the clutch, flywheel and TOB just before Easter.
brad.boyer is offline   Reply With Quote
Old 06-29-2021, 02:13 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Do you hear it in fifth gear?
Old 06-29-2021, 02:14 PM   #3
brad.boyer
Yes!! That's mainly where I hear it. Its also present in third but its pretty quiet.
Old 06-29-2021, 02:40 PM   #4
Ultramaroon
not playing cards
Can you post a recording? I was expecting you to say no. This may not be transmission. Maybe differential.
In fifth gear, the transmission is just spinning along for the ride. The input and output are joined together as a straight shaft.
If it's your daily, better get it in to a shop for a look.
Old 06-29-2021, 02:52 PM   #5
brad.boyer
When you say differential, are you referring to the rings and pinions? Or the actual differential? I'm not sure how to go about working towards a fix. I just started learning about cars about a year ago so my knowledge is fairly limited.
Old 06-29-2021, 03:27 PM   #6
Ultramaroon
not playing cards
It gets complicated pretty quickly. Best to get an experienced set of ears and hands on. Don't wait.
Having troubles starting car Tomahawk Southern California 0 01-31-2016 04:13 PM
Having some troubles with OFT. Vroomin86 Software Tuning 15 06-01-2015 06:54 PM
Manual Transmission troubles (tips are welcomed) Janunez90 Issues | Warranty | Recalls / TSB 14 08-07-2013 03:02 PM
Lug nut troubles Krait1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2013 12:46 AM
Dealer Troubles shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 39 02-23-2013 02:42 AM
