Old 06-28-2021, 05:01 PM   #1
gpvecchi
gpvecchi's Avatar
Ecutek engine load limiters
These are replaced by RaceRom Engine load limiter, but do you know how do they are being applied in stock ROM?
I mean, is like one of the 2 being used in safe mode or else?
gpvecchi is offline   Reply With Quote
Old 06-29-2021, 06:11 AM   #2
steve99
load A and B tables are same make sure you keep them same and also sane as ecutek load table or weird stuff can happen
Old 06-29-2021, 09:18 AM   #3
tomm.brz
Drives: brz 2017 hksv2
If racerom is applied, engine load lim A and B and totally ignored all the time and superseded by ecutek's one like gpvecchi thought .. you could put random low values in A and B table, they 'll get ignored anyway if the tune has racerom
but yeah actually subaru modified them in the very latest restyling oem roms
my guess is one is used during the Power AFR mode , and the other one during normal mode
Power afr and normal afr mode are triggered by catalyst temp, there is a table for it
The Following User Says Thank You to tomm.brz For This Useful Post:
gpvecchi (06-29-2021)
Old 06-29-2021, 04:54 PM   #4
gpvecchi
gpvecchi's Avatar
Thanks Tommy, that I was looking for. Engine load lim B should be the one in normal mode, right?
Old 06-30-2021, 08:29 AM   #5
steve99
People forget ecuitek or romraider are reverse engineering these roms from compiled machine code your not workingcwith the source code.
sometimes when the code is compiled the same table ends up in two places.
This is the case for tables like closed loop fuel tables A and B and the load limot tables A and B also with O2 sensor scaling has tavles a and b.
Its different for timing tables A limp mode low IAM and B normal mode.
If you were working on the actual source code then there would only be one load limit table, but when the compiler runs some tables get duplicated in the compiled code the ecu uses and that we work with.
So if you make those tables A and B different then reary unusual thigs may happen and in some cases it will use A values and some cases B values depending on which path the compliled code uses
This may not matter too much on NA cars but on a boosted car it may cause a drastic lean condition due load truncation.
Yes the ecutek load table is supposed to overide the standard load tables but there has been bugs before
safest to make ALL three load tables same
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Compelica (07-02-2021), gpvecchi (06-30-2021)
Old 07-01-2021, 07:47 AM   #6
tomm.brz
i agree and still have no idea in how to answer to gpvecchi, but i m sure with euro tune and rr12.1 there is no bug, and the engine load limiter by ecutek always overrides the 2 oem tables
Adjusting AFR with Engine Load Compensation (instead of Load Limits) Tor Software Tuning 33 08-17-2021 09:58 AM
Ecutek won’t load updated firmware sroby Software Tuning 10 06-30-2018 12:31 AM
Engine Load Comp (MP) Nah Software Tuning 8 01-20-2017 06:30 AM
Where should my engine load be around idle? Astroboy Forced Induction 8 02-06-2016 02:07 AM
EcuTek Unable to Increase Load Limits Skorov Software Tuning 35 06-25-2014 01:56 PM
