Old 01-19-2017, 12:51 PM   #1
Nah
Drives: 2013 Scion Frs 6mt
Engine Load Comp (MP)
Can someone explain to me what the table is and what it effects please.
Today I decided to Zero Out the engine load comp based on manifold pressure and RPM and nonetheless, I was very impressed with the results.
Downshifting, cruising, and wot was improved. AFR was good and no knock.
Keep in mind my MAF has been scaled and vvt has been changed to accomdate my header as well as some timing tweaks in the .4-.8 range.
Thank you very reading!
Nah is offline   Reply With Quote
Old 01-19-2017, 02:05 PM   #2
aagun
Drives: 86
i think it is rpm x map x maf , not final maf calcu . but it used on the matrix
check ur FUEL TURN
aagun is offline   Reply With Quote
Old 01-19-2017, 02:14 PM   #3
Nah
Did some reading... it effects load/fueling calculations. (Obviously)
Using the VGI worksheet with the values zeroed out I'll do a test and see what the worksheet spits out at me.
Than apply those changes and see how she drives.
If anyone could explain why driveabilty improved that'd be awesome thanks.
Old 01-19-2017, 02:16 PM   #4
Nah
check ur FUEL TURN
Fuel trims? Are good. Just could use a slight re scale due to the temperature change. But yes you're right about the axies... idk if that's the plural form of axis or not? Lol
Old 01-19-2017, 02:44 PM   #5
aagun
Drives: 86
try do same logs in air signs
and compare it
maf is so complex
The Following User Says Thank You to aagun For This Useful Post:
Nah (01-20-2017)
Old 01-19-2017, 03:50 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
It seems to impact in closed loop and is indeed a load compensation table based on MAP.
You change it the same way as the MAF, using fueling error.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Nah (01-19-2017)
Old 01-19-2017, 05:53 PM   #7
Nah
Would the vgi worksheet tool be useful for this? Say I 0 out the table than do my logging. Or would it be better to apply the correction by hand
Old 01-19-2017, 07:40 PM   #8
steve99
as its map based ie pressure compensation you may not see effects of zeroing table unless the air pressure ie altitude changes
Nah (01-20-2017)
Old 01-20-2017, 05:30 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
I use the log stats but I add parameters to my log file for me to be able to do this so I can play with the data. The engine load comp tab does work well though.
.: Stealth 86 :.
Kodename 47 DJ:
Nah (01-20-2017)
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
Load Limits Nah Software Tuning 3 07-15-2016 10:30 PM
Where should my engine load be around idle? Astroboy Forced Induction 8 02-06-2016 01:07 AM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 12:58 AM
