Drives: 2013 Scion FRS
I'm new to cars and my 2013 scion fr-s keeps showing a U0100 and a U0102 code. I was wondering if anyone had any tips on troubleshooting these codes? My car also stalls during idle after running for a little bit and sometimes when I go in reverse?. Any advice would be greatly appreciated.
| The Following User Says Thank You to LadonP For This Useful Post: | humfrz (06-16-2021) |
#2 | |
![]() First off, I'd suggest you check the battery and make sure it's up to the proper voltage. If it isn't, charge it up or replace it. If it's OK, I suggest you take your car to a shop and ask them to fix it. Maybe some DIY -ers will be along to address your cars problem. |
Is the car stock? If not what mods? Did anybody do work in the engine bay or under the dash?
| The Following User Says Thank You to Tcoat For This Useful Post: | RToyo86 (06-16-2021) |
Drives: Crapcan
You didn't happen to have installed an ebay 4th brake light did you?
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (06-16-2021), Tcoat (06-16-2021) |
TRACKBREAD
Need Help!
UXXXXX codes point to a communication fault, not a problem with the actual engine or body control systems.
Is anything plugged into the OBD port? |
#6 | |
Was some weird and wonderful product hooked up to it and screwed something up? Did somebody try to throw a homemade "tune" on?
| The Following User Says Thank You to Tcoat For This Useful Post: | Yoshoobaroo (06-16-2021) |
