Old 06-15-2021, 10:20 PM   #1
LadonP
Drives: 2013 Scion FRS
Exclamation Need Help!
I'm new to cars and my 2013 scion fr-s keeps showing a U0100 and a U0102 code. I was wondering if anyone had any tips on troubleshooting these codes? My car also stalls during idle after running for a little bit and sometimes when I go in reverse?. Any advice would be greatly appreciated.
LadonP is offline   Reply With Quote
The Following User Says Thank You to LadonP For This Useful Post:
humfrz (06-16-2021)
Old 06-16-2021, 12:56 PM   #2
Hi ya, there, LandonP and welcome to our forum -
First off, I'd suggest you check the battery and make sure it's up to the proper voltage.
If it isn't, charge it up or replace it.
If it's OK, I suggest you take your car to a shop and ask them to fix it.
Maybe some DIY -ers will be along to address your cars problem.
Old 06-16-2021, 01:00 PM   #3
Is the car stock? If not what mods? Did anybody do work in the engine bay or under the dash?
RToyo86 (06-16-2021)
Old 06-16-2021, 01:10 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You didn't happen to have installed an ebay 4th brake light did you?
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (06-16-2021), Tcoat (06-16-2021)
Old 06-16-2021, 01:11 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Need Help!
UXXXXX codes point to a communication fault, not a problem with the actual engine or body control systems.
Is anything plugged into the OBD port?
Old 06-16-2021, 01:14 PM   #6
Is the ECU screwed on proerly so it is grounded?
Was some weird and wonderful product hooked up to it and screwed something up?
Did somebody try to throw a homemade "tune" on?
Yoshoobaroo (06-16-2021)
