Old 06-09-2021, 11:17 PM   #1
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Open flash tablet
So my FR-S came with an open flash tablet. My question is this, is there a way to know what tune my car currently is running? I’m not exactly sure how to use it. I mean I’ve gone through it and I can see how it works but I don’t know how to see what tune my car is running if any at all. For now I’ve put 91 octane in because that’s what it is supposed to have. Would I know that it is running on an e85 tune? Any advice would be great. Thanks guys!
Sur is offline   Reply With Quote
Old 06-10-2021, 09:51 AM   #2
Boomerang
86
Boomerang's Avatar
Sure can, you connect the OFT to your car first.
Select the INFO button.
Your tune will be shown under the FILE IN ECU line.
This description will tell you what file you are running, let us know what the file name is anyway..
Old 06-10-2021, 10:47 AM   #3
Sur
Sur's Avatar
Okay I will check today on my lunch break. Thanks for the reply. And I will post the file name as well.
Old 06-10-2021, 06:05 PM   #4
Sur
Sur's Avatar
File is. ECU pop-pop.bin
Old 06-10-2021, 06:29 PM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Sounds like a tinkered with tune. The pop and crackle tunes usually are less responsive by how they make the sounds
gen3v8 is offline   Reply With Quote
Old 06-10-2021, 07:14 PM   #6
Sur
Sur's Avatar
Yea well when I let off the gas, as it’s decelerating, it does pop a little
Old 06-10-2021, 07:21 PM   #7
Sur
Sur's Avatar
So is it safe to change it to a standard stage 1 or 2
Old 06-10-2021, 07:22 PM   #8
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
You start decelerating and slightly touch the throttle.Try that. That`s how it works and can be set for an rpm range.
Old 06-10-2021, 07:31 PM   #9
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
The tune 1/2 depends on your mods. If you plug the oft into your pc with openflash manager installed you can see what tunes are in the oft.
Old 06-10-2021, 08:47 PM   #10
Sur
Sur's Avatar
Yea that pretty much what happens.
I’m still trying to figure out exactly what mods I have since I bought it used from a dealership and they didn’t have much info about that aspect.
I don’t wanna damage anything so i guess since it is running fine I should not do anything until I get some more answers.
Old 06-10-2021, 10:10 PM   #11
iag48st
Drives: 10Series 0945
Little high jack but how do you check oil temp oftv2? Do I need an aftermarket sensor?
iag48st is offline   Reply With Quote
Old 06-11-2021, 03:15 PM   #12
Sur
Sur's Avatar
So what’s the best way to figure out what file to download from OFT site. I search GT86/FRS/BRZ 2013 6MT and there is a ton. How do I get the most recent updated one?
Old 06-11-2021, 04:29 PM   #13
rbfr.s
rbfr.s's Avatar
Drives: 2014 FR-S
If the tablet doesn't already have them loaded from the previous owner you will want to download: Stage 1, Stage 2, Stage 2+. From there you can add more or learn how to tinker with the tunes through the application RomRaider. Is there an "original file" saved on the tablet? That would be your stock ECU map.
Professional Car Breaker
rbfr.s is offline   Reply With Quote
Old 06-11-2021, 04:44 PM   #14
Sur
Sur's Avatar
Yea there is an original. Also there is a stage 1 and 2 stage 2 and the one custom it’s running. But I was of the understanding that I should be using updated tunes from the OFT site. So I just was looking and there are a lot. I don’t wanna install something that will hurt my ecu or anything else. So I’m just looking for a safe tune I can install and not have this dumb pop tune that is on it currently.
Update*
So today I installed the stage 2+ OFS on MY FRS and got rid of the pop tune that it came with. Feels so much better. Everything went smooth and I got the scary first time tune virginity feeling out of the way.
I’d like to thank everyone for their advice and help. I appreciate every single one of you!
e85, open flash tablet, tunes
SOLD: Open Flash Tablet, Open Flash Header, Crawford Power Blocks Totemo_Hayai Engine, Exhaust, Bolt-Ons 14 09-15-2019 02:28 AM
My experience with Shiv & his products at Open Flash Tablet / Open Flash Header TouchMyHonda User/Vendor/Sponsor Reviews, Feedback, Comments 5 10-23-2015 09:57 AM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
