Drives: subaru brz 2017 wrb
e85 flex fuel supercharger stock engine reliability
I know it is pretty reliable to be under 300 whp on pump gas with a supercharger kit on the stock engine. However, how about the reliability of using a flex fuel kit with supercharger (such as edelbrock), where it is tuned with e85 to I think I've seen around 330whp? Should I be worried about the engine blowing at that power level on a full tank of e85 for the long-term (100k-200k miles)? This is all assuming I have the correct supporting mods of course (e.g. brakes, wheels, tires, clutch, etc). Any data to support conservative tunes, for example maybe 320 whp on e85, is safe in the long-term? I plan to do track days and spirited driving here and there, and dailying the car for now.
Drives: 2017 BRZ Series. Yellow
From the reading in the Edelbrock thread and from the 10k miles I've put on mine it's been perfect so far. That being said I do try to limit my right foot under 3k rpms and I'm being very conservative with my oil changes running motul out to 3k miles.
#3 | |
Remember, if you double your power, plan on doubling your cooling. PM me to order. |
Mike, Thanks so much for the input. Assuming there is good conservative tune, supporting mods, and cooling, have you ever heard of anyone who still blew their engine on e85 after using it for a long time (100k-200k miles)?
#5 | |
It really depends on luck of the draw, as well as your use case and maintenance. If you do it right, it should last a long time. Many folks cut corners, while also claiming to have a much more powerful car than a factory car, with much lower cost. There's a reason why XYZ car cost $ABC dollars, with more power from the factory. |
| Edelbrock Supercharger - Built Engine - 420 WHP on Flex Fuel | DeliciousTuning | Forced Induction | 26 | 04-12-2022 02:25 PM |
| SOLD: Complete Edelbrock supercharger kit with flex fuel and extras SEATTLE ONLY | johnbrz | Engine, Exhaust, Bolt-Ons | 13 | 06-29-2020 04:14 PM |
| Supercharger on stock motor reliability? | BluePaperClips | Forced Induction | 19 | 09-29-2016 01:14 PM |
| Flex fuel and supercharger? | sandwich14 | Forced Induction | 23 | 01-05-2014 08:49 PM |
