Old 06-06-2021, 04:44 PM   #1
Fiend
Drives: Boosted frs
P062d & p0451
So recently I upgraded my turbo kit (headers, intercooler & turbo). After I installed everything I have no pedal response. My engine revs constantly 1k to 2k. The only thing I changed out besides the kit was a02 sensor could that be the cause? Any suggestions would be appreciated.
Fiend is offline   Reply With Quote
Old 06-11-2021, 11:41 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
P062D is either an open or short on the DI injector driver circuit or another fault related to the DI driver or ecu. I would check all connections to the injectors and driver module, and make sure the driver module screws are tight. It ground through it's mounting screws.
P0451 is a difference in the evap canister pressure sensor output and the map sensor output. Check for a damaged hose, or electrical connector for the sensor to the evap canister.
Old 06-13-2021, 03:04 PM   #3
Fiend
Drives: Boosted frs
I appreciate it a lot. Who would’ve thought a loose bolt would stress me out this much. The p0451 cleared up on its own so I’m not sure what happened there.
The Following User Says Thank You to Fiend For This Useful Post:
NoHaveMSG (06-13-2021)
Old 03-27-2022, 10:32 PM   #4
strat61caster
strat61caster's Avatar
Omg lifesaver. Thought I had ducked up my injectors, rough running, misfires, wouldn’t hold idle. Ecu wasn’t grounded, bolted it down, problems gone.
ineedyourdiddly
02 sensor, avo turbo kit
P0451 FirestormFRS Issues | Warranty | Recalls / TSB 10 05-02-2023 11:56 PM
Problems related to code: P0451 Teratorry Issues | Warranty | Recalls / TSB 1 07-23-2020 01:52 PM
P0451, P0451, P0453 Fix? jaimeFRS Scion FR-S / Toyota 86 GT86 General Forum 3 04-29-2020 03:01 PM
P0451 & U1201 after JRSC installation. Thepest Northern California 1 04-06-2020 07:22 PM
P062D Cobiflex Issues | Warranty | Recalls / TSB 5 09-12-2019 10:49 AM
