Problems related to code: P0451
I have been having an issue for the last couple days.
Engine Mods: JDL v2 turbo kit, oil catch can, Omni 3bar MAP sensor The first thing that happened was that I was getting some hesitation in my throttle. From a stop I would attempt to give the car gas and the rpms would drop to almost a stall and reattempt to go back to an idle. Throughout the gears, the throttle doesn't respond immediately so my shifts are rough. Later on, as I would slow down to a stop, the car actually did stall. When I started it again, it threw a code: P0451, which is related to the EVAP solenoid. So, I checked the hoses under the manifold but they are all still clamped down and in place. Something else I noticed is that my Openflash Tablet is showing the boost at a constant -2.45 and won't move no matter how much pressure there is, so I tried a few things. First I unplugged the 3bar Omni MAP sensor while the car was off but the key was on, which reset the boost to .15 (when off). I started the car and it showed boost at normal levels and the car drove like a dream, but then after about 5 min of driving the boost # on the tablet went back to -2.45 and started all the symptoms over again. I've also tried to just reflash the tune, but that didn't do anything. I haven't had any issues after installing the kit almost a year ago. I've already emailed my tuner about the issue, but no response yet. Any ideas? |
SOLVED: I disconnected the battery and unplugged the MAP sensor and the blue plug in the back of the manifold to the EVAP solenoid. I left it for a few minutes and plugged the EVAP back in then the MAP, then I reconnected my battery. Before starting my car, I reflashed the tune using my OFT. I have been running it a few days with no issues or codes. I can't really explain why what I did worked but it seemed to have none exactly what I was hoping.
| P0451 | FirestormFRS | Issues | Warranty | Recalls / TSB | 10 | 05-02-2023 11:56 PM |
| P0451, P0451, P0453 Fix? | jaimeFRS | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-29-2020 03:01 PM |
| P0451 & U1201 after JRSC installation. | Thepest | Northern California | 1 | 04-06-2020 07:22 PM |
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
| Problems updating form ZA1JA01G to ZA1JD00G ROM - fixed disable U0155 code in rom | steve99 | Software Tuning | 38 | 09-03-2014 06:44 PM |
