What's this thing on header?
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
Drives: 2013 frs red
The springs hold the pipes to each other. Looks like a motorcycle pipe
30 minute maintenance
Drives: My18 wrxsti
It`s for movement of the pipe as it expands and shrinks with temperature changes. The joint helps prevent stress fractures/cracks and the springs obviously keep it together.
not playing cards
^^this^^ The stock header and many others use a flexible bellows for the same purpose.
This is pretty common with motorcycle exhaust designs, the pipes have a pretty tight slip fit and the springs keep them pulled together snug. I've had a couple bikes with several joints like this and it was never an issue.
Thanks. So pipes are not welded there, but just slipped in?
Wouldn't this lead to leaks? |
#8 | |
Anti stance.
#10 |
Now the opposite question: headers like JDL doesn't have anything against thermal stretching, wouldn't this be an issue too?
#11 |
Drives: '15 BRZ RA
Looking to buy the Toda Racing header?
#12 | |
Drives: 2014 GT86
"2nd" generation of headers mostly hadn't such, probably because due collected more statistics it seemed that in most cases headers worked fine without observed excessive welds cracking or alike even without those flexible joints, so decided to not include them to simplify & cheapen design/production. So imho no, it shouldn't be an issue if there is such or not, as far as in general you don't see much issues reported regarding particular header you intend to buy. Some worse quality headers (or other aftermarket exhaust bits, eg. catback) may see cracking welds even with such joints, and opposite, good ones may last just fine without. |
#13 | |
They got rid of them though and it apparently hasn't caused any issues. There is some thought that flex joints are fragile and susceptible to failure. ![]() I wouldn't worry about it too much as long as your header is made by a reputable manufacturer with experience on the platform.
2022 BRZ Build 2013 FR-S Build |
| What is this thing? | pallen | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 07-01-2020 10:23 PM |
| What is this thing? | jabe | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 09-19-2018 05:34 AM |
| What Is This Thing? | Kaotic Lazagna | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 05-18-2016 09:53 PM |
| I Did a Thing | STZ | BRZ First-Gen (2012+) — General Topics | 19 | 02-15-2016 07:40 PM |
| First thing you are going to do when you get your BRZ? | Norcalmav23 | BRZ First-Gen (2012+) — General Topics | 74 | 04-02-2012 11:05 PM |
