Old 09-17-2018, 12:11 AM   #1
jabe
Drives: 2017 Toyota 86
What is this thing?
I'm a fairly new owner and also overly curious how things work.
I see on top of the dash, forward near the windshield, passenger (right) side, there's a small, raised dome-shaped "button". I can't quite tell if it's molded into the dash, or a separate part that might be removable. (In a symmetric position on the driver's side, there's a circular depression.) What the heck is it? (I thought maybe it's a daylight sensor for the headlights, but I'm pretty convinced now that it isn't.)
And if it's not the daylight sensor, where the heck is the daylight sensor?
(I've probably got a few more silly questions coming!)
jabe is offline   Reply With Quote
Old 09-17-2018, 12:46 AM   #2
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Passenger side is a sensor which tells the headlamps to turn on or off when the headlamp switch is in the auto position.
Driver's side, depression in same area simple means there's nothing there, on that side.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
FRSBRZGT86FAN (09-17-2018)
Old 09-17-2018, 01:02 AM   #3
jabe
Thanks for that. It does make sense, but I had convinced myself it wasn't that, by covering it. I'll play with it again.
Old 09-17-2018, 01:14 AM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You'll have to do better than that to trick it, try black electrical tape and watch what happens
Old 09-17-2018, 02:55 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Or..... you could try and read the owners manual. It has info you really should know about your car.
Yes even your original question is covered in there.
The Following 6 Users Say Thank You to Mr.ac For This Useful Post:
Crashdummy (09-18-2018), extrashaky (09-17-2018), JohnJuan (09-17-2018), pinoy_dorifto (09-17-2018), Spuds (09-17-2018), Tcoat (09-17-2018)
Old 09-17-2018, 05:08 AM   #6
accwai
初級成員
Drives: 2017 86, 2010 Corolla
Originally Posted by Mr.ac View Post
Or..... you could try and read the owners manual. [...] your original question is covered in there.
Yup, it's in 2017 86 Owner's Manual at the top of p.174.
accwai is offline   Reply With Quote
The Following User Says Thank You to accwai For This Useful Post:
Chimera (09-17-2018)
Old 09-17-2018, 01:35 PM   #7
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I don't know why they bother printing the thing. They should just do what everyone else does and just leave a card with a web address in place of the manual.
PetrolioBenzina is offline   Reply With Quote
Old 09-17-2018, 01:41 PM   #8
FRSBRZGT86FAN
It's definitely a legal thing, but they did provide it with scions, you could go onto the scion owners portal thing and get the entire owners manual online. No doubt subaru and toyota do the same now.
Old 09-17-2018, 01:47 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I want a printed manual, thank you very much.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
funwheeldrive (09-17-2018), spike021 (09-17-2018), yurikaze (09-19-2018)
Old 09-17-2018, 01:52 PM   #10
FRSBRZGT86FAN
You might, but a searchable PDF would really make it easier for people
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 09-17-2018, 01:52 PM   #11
"What is this thing?"
Old 09-17-2018, 01:59 PM   #12
spike021
spike021's Avatar
Good luck in the middle of nowhere when your phone dies and you absolutely need to check something in the manual.
Also, manuals have an index and page numbers. It's actually super easy to glance at the back, find the thing you need, and then go to the correct page number. That's probably even quicker than searching a PDF.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
Tcoat (09-17-2018)
Old 09-17-2018, 02:23 PM   #13
FRSBRZGT86FAN
Or you could, you know, read the manual before and learn about your car so you don't run into a situation where you don't know where something is or what something does. But that's just me....
Tcoat (09-17-2018)
Old 09-17-2018, 02:27 PM   #14
When I bought the car they needed a couple of days to prep it. I took the manual home and read it through. When I picked up the car I was able to set everything up how I wanted before I even left the lot.
Dadhawk (09-17-2018), FRSBRZGT86FAN (09-17-2018)
What Is This Thing? Kaotic Lazagna Scion FR-S / Toyota 86 GT86 General Forum 20 05-18-2016 09:53 PM
I Did a Thing STZ BRZ First-Gen (2012+) — General Topics 19 02-15-2016 07:40 PM
New JDM BRZ STI lip & under-lip thing JasperNoone Exterior Parts (Aero, Lighting, Etc.) 5 06-30-2014 03:56 PM
If you could add 1 thing to your FRS/BRZ/86 what would it be? Dazza Scion FR-S / Toyota 86 GT86 General Forum 84 10-18-2013 05:18 PM
What is this thing? ducks Issues | Warranty | Recalls / TSB 7 01-10-2013 05:54 AM
