Old 05-30-2021, 10:27 AM   #1
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
MT trans fluid spec
Hi guys.
I just want to know your opinion about API spec for our MT fluid as i searched a lot about it and found that many people said use GL-4 spec but when I go for owner manual. It said GL-3 or upper grade or even in the 2018 manual which i found in online also spec for API GL-3, 4 and 5. Does GL-5 really safe for the synchromesh?
pym19109 is offline   Reply With Quote
Old 05-30-2021, 03:28 PM   #2
blatantanomaly
Drives: 2016 BRZ Limited
I know people on here swear by Motul Gear 300 which is GL-5 but my transmission felt like complete trash with that fluid. It was like a 1990s domestic. I have had great luck going to Red Line MT-90 which is GL-4. What I remember from looking for answers was that GL-4 was better than GL-3 in every way but GL-5 is fundamentally different and can attack yellow metals.
https://bobistheoilguy.com/forums/th...vs-gl-5.37720/
blatantanomaly is offline   Reply With Quote
Old 06-01-2021, 05:30 AM   #3
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
GL4 is fine for the gearbox, however GL5 is not recommended at all, do not use GL5 in the gearbox. GL5 for the differential only.
sneaky_pete is offline   Reply With Quote
The Following User Says Thank You to sneaky_pete For This Useful Post:
Wally86 (06-03-2021)
Old 06-01-2021, 06:41 AM   #4
54fighting
Drives: 2020 toyota 86
Whats wrong with the factory fill??
54fighting is offline   Reply With Quote
Old 06-01-2021, 08:07 AM   #5
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I found the OEM gearbox oil to have very poor cold weather performance. Switched to Redline, and it's way better.
Cephas is offline   Reply With Quote
The Following User Says Thank You to Cephas For This Useful Post:
Old 06-01-2021, 01:10 PM   #6
DarkSunrise
DarkSunrise's Avatar
Motul Gear 300 is GL-4/GL-5 rated, so fine to use in our transmissions and won't damage any yellow metals.
https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492016023
That said, I don't think it's any better than stock for cold shifts. I use it primarily for the shear protection at the track, but if I was doing a lot of daily driving, I'd probably try something else (like the Redline MT90 you mentioned).
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
BRZ Hachi (06-01-2021), callisto (04-10-2023), Wally86 (06-03-2021)
Looking to change my trans and diff fluid soon, what your guy's go-to and why? 1234eher Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 68 06-23-2023 12:34 AM
What Manual Trans Fluid Do You Use? McG86 CANADA 50 03-22-2020 09:19 PM
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 11:44 AM
Change trans fluid thru dipstick bigsley18 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-18-2013 11:16 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
