Drives: BRZ - GReddy Turbo T518z
Engine Rough idle and cursing sometimes
Engine Rough idle and cursing sometimes it is normal some time rough again i check the fuel pressure, map and maf sensor all constant reading but still rough
Drives: 2020 Toyota 86 GT 6M
any error codes? what do you mean when you say cursing? i've never heard of an engine dong that.
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
must have some pissed off crickets :O
#4 | |
![]() As @saltywetman asked: * What is cursing (you or the engine) ? - ![]() * Is the engine throwing any codes? If so, what codes? How many miles/kilometers on the spark plugs? Have you had any previous problems with the coil packs? Come back. |
#5 | |
no there no codes now, before i month it give fuel rail pressure low put nothing now. i have an air fuel ratio gauge it go rich then lean. i change the plugs in about 40K. and no problem with the coils |
ProCrastinationConsultant
your car has a turbo? have you talked to your tuner to make sure that nothing with the tune needs to be adjusted?
do you have the datalogs?
Mileage? Coil and spark plug age?
2013 Series 10 FRS #553
| Engine Stalled, Rough Idle And Knocking Noise On Startup | Slade | Issues | Warranty | Recalls / TSB | 49 | 09-28-2020 10:13 AM |
| Rough Idle | DeathToocher | Engine, Exhaust, Transmission | 18 | 03-20-2020 10:45 AM |
| Engine running rich, stumbling, rough idle after motor swap | toyubie | Engine, Exhaust, Transmission | 19 | 04-07-2018 12:11 PM |
| Took my car in for rough idle... | Da Brz | Issues | Warranty | Recalls / TSB | 34 | 10-29-2016 12:57 AM |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) General Topics | 20 | 05-22-2014 06:40 PM |
