Old 08-02-2017, 04:37 PM   #1
toyubie
Drives: none
Engine running rich, stumbling, rough idle after motor swap
TL;DR Aftermarket/higher flow/non-stock port injectors were installed on donor motor. Swapping for stock solved my issues.
Big thanks to Kodename47, Turdinator, and steve99 for analysis of my shitty data logs and pointing me in the right direction!
Hey everyone, kind of a long story but I'll make it short...
During a clutch replacement, I was careless and did not properly align the transmission before using bolts to pull it towards the motor. God bless aluminum, the block cracked right the fuck apart like a pistachio.
So, the next few months were spent saving pennies until I found a used motor from a trustworthy source, who was upfront about the motor being raced on for a couple seasons, but was running well with no leaks and only pulled to eventually build/turbo.
Motor swap was ridiculously easy (why doesn't every car have an engine harness disconnect???), and aside from snagging one of the camshaft position sensor wires on the front brace on the way in, everything plugged right back in.
It's been a few months since then, but the following issues have persisted, and all my efforts to remedy them have been unsuccessful. I'm about ready to pull the motor and try again from the beginning.
CEL Codes
  • P1170 - Port Injector Fuel Performance Does not come on DTC
  • P0172 - System Too Rich (Bank 1)
Symptoms
  • Car usually requires a pump of the gas pedal during crank to start
  • On hot days, or after driving (3-10 miles), motor will idle hunt/rough idle on startup, and occasionally at stoplights
  • Through every gear, if the pedal isn't to the floor, motor "bucks" or hesitates/stumbles passing 3-3200RPM. Can be avoided by letting off the gas and feathering past that RPM range (it's my daily driver, second nature by now)
  • Slip indicator lights up as well (I understand this is a running rich indicator)
  • Cruise control disabled (orange, permanent indicator if pushed)
Attempted Fixes
  • Exhaust gaskets (headers, overpipe, front, donut)
  • Intake
    • New filter
    • Tightened clamps
    • Cleaned MAF
    • Replaced air box assembly
  • Tightened O2 sensors, cleaned connectors
  • Re-seated fuel lines, EVAP line
  • Checked for other vacuum leaks
So, what's next? Spark plugs? The injectors are from my original motor, but could potentially be installed incorrectly? I'm not sure about the port injection. What steps can I take there?
I've considered purchasing an OFT and flashing a 91 tune to see if there's just enough of a clearance issue with this motor vs. original that my ECU isn't taking a liking to.
A final thought, at the time of purchase, the motor did not have a HPFP installed, so the pump from my old motor was installed. Could I have botched this as well?
Any guidance or thoughts are appreciated.
toyubie is offline   Reply With Quote
Old 08-02-2017, 05:15 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Pumping the gas pedal during start actually reduces fuel. The symptoms are too much fuel. Is the DI ECU connected and grounded correctly to the block. Is the block ground itself good?
Realistically this is going to be one of if the above isn't correct.
MAF Sensor
Primary O2 Sensor
Injectors
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-02-2017, 05:45 PM   #3
toyubie
Drives: none
Visual inspection shows all plugs are firmly seated and clipped in place. No loose bolts; I did not see a dedicated ground from the DI ECU. Both motor grounds are also attached.
What would be an appropriate method of testing for a solid ground connection? Continuity test?
MAF Sensor
Primary O2 Sensor
Injectors
I'll start researching to verify these components, thanks!
Old 08-02-2017, 06:53 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
It has 3 bolts. IIRC it's the lowest bolt that grounds it to the block, the other 2 connect to the injector covers.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-02-2017, 10:00 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
Did you swap the fuel system from your old motor to the replacement motor or just use what came on the replacement motor?
1974 TA22 Celica
2013 86 GT
Old 08-02-2017, 11:36 PM   #6
toyubie
Drives: none
I confirmed that the third lower bolt is secure.
I did not swap the DI ECU, only accessories (alternator and AC compressor) and the HPFP. Is the DI ECU married in some way to the engine ECU?
Old 08-02-2017, 11:49 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
I don't know for sure. When I swapped my motor I used the old DI ECU. If you still have it, it would be a quick thing to check but my guess is that since the code you are throwing is port injector related it isn't your issue.
My line of thinking was more maybe the motor you bought had an existing issue with the injectors or even the motor loom?
Do you have any mates with an OFT that could look at your AFRs?
1974 TA22 Celica
2013 86 GT
Old 08-03-2017, 12:05 AM   #8
toyubie
Drives: none
Good point. I sold the original motor back to one of the seller's friends, I'm not sure what state it's in now. Probably rebuilt and getting beat on by now haha
I didn't see any apparent damage on the loom, aside from the sensor wires I snagged and ripped. I'd imagine if there was any significant damage it'd be throwing more codes or running worse than it is now. Very hard to inspect thoroughly now.
I posted on a local Facebook group to see if anyone would be willing to meet up and log some data for me. In the meantime I'll go at it with a multimeter tomorrow and see if the O2/MAF sensors seem okay.
Old 08-03-2017, 12:25 AM   #9
steve99
DI computers are all same no problem swapping
were the port fuel injectors stock on the transplant motor ?
I think you going to have to log ecu parameters like
mafV
maf
stft
ltft
port injector pulse widths
DI pulse widths
AFR
Commanded AFR
to try to diagnose problem
If you see high positive ltft a likely cause is exhaust leak before or near first 02 sensor. this allows fresh air containing oxygen to get to sensor between exhaust pulses at low rpm, ecu thinks its lean adds fuel with positive ltft, but makes car rin super rich at low rpm.
At higher rpm enough exhaust pressure to exclude outside air so its usually ok over 3000 rpm
have a look here
[ame="https://www.youtube.com/watch?v=5WnM_NsOtd8"]Secret of Engine Problem Diagnosis- Fuel Trims Pt.1 - YouTube[/ame]
Old 08-03-2017, 04:46 PM   #10
toyubie
Drives: none
Yes, as far as I know, everything is stock.
mafV
maf
stft
ltft
DI pulse widths
AFR
Commanded AFR
I was able to log a few of those parameters through Torque. I watched part one and part two but I'm still having trouble understanding the data I logged:
From my understanding, and this data, it appears the car is running lean? I did not notice the slip indicator come on during the drive; maybe the cool day today is pushing the car in the opposite direction of my overall experience?
Not sure what the make of the O2 data, I chose the two parameters available with voltages.
Maybe someone can take a closer look?
https://docs.google.com/spreadsheets...it?usp=sharing
However, it does appear as though the sensors are functioning correctly... or, at least sending data.
Old 08-03-2017, 11:26 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
Looking at the raw data you have some huge negative trims in places but not everywhere. I definitely wouldn't be going WOT near redline often if I was you, you're running very lean up the top end.
My first thought was that your PI are running very rich but your DI is relatively normal which is causing the lean AFRs as the DI is phased in. I would be triple checking your fuel hoses are all connected in the right way and investigating whether your PI are stock. Can you log fuel rail pressure in for PI and DI?
Also look into making a datazap account. It will make viewing your logs much easier for us.
1974 TA22 Celica
2013 86 GT
Old 08-04-2017, 12:57 AM   #12
steve99
Its difficult to draw a lot from those logs as you need to know throttle position engine load rpm as well as the other parameters and need them all on one graph.
The AFR look kind of normal but the ecu is having to apply a large negative fuel trim to keep the afr in check. Ie its wanting to run rich but the ecu is applying a lot of negative fueling correction to stop it running rich.
This could be due to a number of issues
if you have another maf sensor available or a mate will lend you one might be worth swapping one in. Check the maf sensor isn't in backwards (not sure if its even possible)
could also be leaking injectors.
or your new motor had larger port injectors fitted.
Old 08-04-2017, 06:32 AM   #13
toyubie
Drives: none
I appreciate the input from you guys, it's been very helpful!
Can you log fuel rail pressure in for PI and DI? Also look into making a datazap account. It will make viewing your logs much easier for us.
Fancy! I enabled logging of all relevant sensors available in Torque:
(http://www.datazap.me/u/toyubie/brz-...=2-3-7-9-10-15)
What would be a way to tell if larger port injectors have been fitted (would there be a huge physical size difference and what would I compare it to)? In any case, I think the MAF or injectors sound much more likely to be the issue. I haven't found my multimeter, but I can certainly swap out my injectors tomorrow.
Old 08-04-2017, 07:05 AM   #14
steve99
picture of stock port injectors in link below no one updateds the DI injectors, just the port injectors.
http://www.ft86club.com/forums/showthread.php?t=11242
You rearly need to get someone to diagnose it further before you start spending money on parts, check injectors are stock sure and maybe swap a maf sensor in, but after that you might want to think about a tune shop with brz/Subaru experience having a look
Im thinking it might be port injectors as if you look at the port/direct tables in rom below.
0 means full Direct
then the 30 20 or 50% is amount of Port injection
Your fuel trims are worst when its using most port injection ie around 2000 rpm then it seems to get better as the rpm climbs a bit further and you start using all direct injection
Engine Running Rich, P0102 P0108 P0113, and Misfires Votlon Engine, Exhaust, Transmission 12 01-21-2017 03:38 AM
OFT+OFH running rich Dabrown Software Tuning 14 11-28-2016 03:20 PM
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 01:55 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-25-2013 11:42 PM
running rich/stumbling Boostedpro Issues | Warranty | Recalls / TSB 1 01-28-2013 02:19 PM
