Old 05-15-2021, 06:19 PM   #1
Chef0
Drives: 2013 Scion FRS
EJ20Y Swap
Recently, unfortunatly, I have been in the market for a new engine. I was looking into swapping a WRX engine into my 2013 Scion FRS to maybe get a bit more power. But i dont know the first thing about swaps. How much horsepower would require a new transmission, or a new clutch, other upgrades? What engines would require the least amount of internal changes? I was looking into a EJ20, but wasnt sure if that was a good idea, or if there were better, and or cheaper options. Or if id just be better off getting another FRS engine.
Chef0 is offline   Reply With Quote
Old 05-15-2021, 06:33 PM   #2
Ashikabi
Ashikabi's Avatar
WRX engine doesn't fit. 2AZ-FE, K, and LS are the only "practical" options, closely followed by the 2JZ which costs a little more. You're looking at almost 10,000$ for a bare minimum swap. The fastest of which being the LS. Unless you're really dedicated to the your particular FRS, just replace the motor. Boost it if you want more power a boosted FRS is as fast if not faster than a sub-10k$ LS swap.
Old 05-15-2021, 08:35 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
I don't think I've even seen a sorted EJ swap that wasn't a race car running on a standalone. As said above, just throw another FA20 in it.
PulsarBeeerz is offline   Reply With Quote
Old 05-17-2021, 05:35 AM   #4
Tomm
Identifying as a Member
Tomm's Avatar
Drives: 2013 FRS LS1
Ashikabi makes a good point.
What is your budget? That will dictate what option is best for you.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline
Tomm is offline   Reply With Quote
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
CTS-V BBK Swap Soloside Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-14-2017 03:03 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
