Old 05-13-2021, 06:46 PM   #1
nicole.jacoby222
Drives: 2013 Subaru BRZ
Fuse problems
I’m reaching out hoping to get an idea of solutions or recommendations, I’ve got a 2013 Subaru BRZ I left me fog lights on before work after work car wouldn’t start. Replaced the battery but the car still wouldn’t start. Turned out I popped a fuse which I found to be 15A EFI (CTRL) I replaced the fuse but car shut off 100ft down the road. When I put new fuses in it will start but pops every time my car goes around 5k rpms. It’s an extremely temporary solution but I wouldn’t say it’s drivable.
nicole.jacoby222 is offline   Reply With Quote
Old 05-15-2021, 02:30 AM   #2
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Welcome to the forums! I am going to state the obvious but did you clean your battery terminals? It sounds like the fuse is getting overloaded causing it to blow. Do you have any mods? Mileage? Did you notice anything out of the blue besides leaving your fog lights on? Check engine light? Any codes if check engine light? Maybe a ground wire is loose causing your car to freak out.
scion fr-s is offline   Reply With Quote
Old 05-31-2021, 09:06 PM   #3
nicole.jacoby222
Took it to the shop and they replaced the intake manifold, everything’s running again like it used to
Old 06-01-2021, 12:55 AM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Pardon the inquiry, but how the hell does one fix a fuse blowing issue by replacing the intake manifold?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
soundman98 (06-01-2021)
Old 06-01-2021, 01:40 AM   #5
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Anything is possible when you are a bot
2020BRZtS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post:
soundman98 (06-01-2021), Tcoat (06-01-2021)
Dashboard fuse box - mini fuse removal airrick Electronics | Audio | NAV | Infotainment 0 10-25-2019 05:05 PM
Fuse Help! KungFuWaffle Electronics | Audio | NAV | Infotainment 0 11-29-2017 02:41 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
Fuse box. Chen Northwest 4 01-19-2015 03:51 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
