Old 05-13-2021, 04:13 PM   #1
Dububster
Dububster's Avatar
Exhaust Hissing when in lowering rpms
Hey guys, so I have been hearing this sound for a while now and always thought it was an exhaust leak, but after many hours of looking for said leak and not finding one, I ended up taking it to an exhaust shop and having them take a look at it. It turns out I was right, and there is no leak. So the sound I'm hearing is when I'm accelerating in the lower RPMs I can hear this hissing sound whenever I am driving next to a wall or something like that. I have a gruppe-s catless uel header and a perrin Catback. This sound goes away when I put my stock header back on to check, so it makes me think it could be just rasp, but when I have looked into that header catback combo, I've only seen people been saying it has zero rasp. Does anyone have any input on what might be going on?
Dububster is offline   Reply With Quote
Old 05-13-2021, 04:36 PM   #2
Project_1796
Drives: Scion FRS 10 series
I have the Tomei UEL header, a overpipe, and a motive front pipe with stock catback, I do hear the noise, it's the exhaust AVCS activating, you can try tuning the overlap or let it be
Project_1796 is offline   Reply With Quote
The Following User Says Thank You to Project_1796 For This Useful Post:
Dububster (05-13-2021)
Old 05-13-2021, 06:19 PM   #3
Dububster
Dububster's Avatar
Oh, interesting, I had no idea that was a thing. I really appreciate the insight.
Old 05-13-2021, 06:21 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A head without insulation can make a hissing sound. Eventually my head failed, and it was a totally different effect.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (05-14-2021)
Old 05-13-2021, 06:34 PM   #5
Dububster
Dububster's Avatar
If the head wasn't insulated, wouldn't there still be a noise when the stock headers were put back on?
Old 05-13-2021, 09:14 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Dunno. I never tried that with the stock header. Possibly. Probably if you take out the cats. Also more likely with thinner metal aftermarket heads. On my gen 1 Borla, it was super noticeable. Sounded like snakes.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Dububster (05-14-2021), Ultramaroon (05-14-2021)
Old 05-13-2021, 09:53 PM   #7
Project_1796
AVCS is almost like Honda's VTEC system but activated by different means, subaru has the ability to control both intake and exhaust camshaft timings on the FA20 for valve overlap, depending on the exhuast manifold design, the engine noise & exhaust note will sound different depending on how it's tuned. The stock exhaust manifold is more of a equal length design, so when you place it back on noise goes away.
Old 05-14-2021, 02:08 AM   #8
Dububster
Dububster's Avatar
Gotcha, I'm very happy to hear it's normal. I have my car tuned with the oft. Would that affect it at all, or is it strictly the headers?
Old 05-14-2021, 02:18 AM   #9
Dububster
Dububster's Avatar
What do you exactly mean by not insulated head? And would there be any other symptoms of that?
Old 05-14-2021, 02:34 AM   #10
Project_1796
[QUOTE=Dububster;3432453]Gotcha, I'm very happy to hear it's normal. I have my car tuned with the oft. Would that affect it https://www.comeanddriveit.com/engin...avcs-explained
Here's more info on the avcs system. There's also a post here on the forums about different cam profiles for exhaust manifolds.
Take a peek here at steve99's tune tweaks under avcs section
https://www.ft86club.com/forums/showthread.php?t=74754
Old 05-14-2021, 10:30 AM   #11
GraysonGreene
GraysonGreene's Avatar
Drives: 2014 Scion FR-S
Same here. I bought my FR-S with gen 1 Borla UEL's and replaced them with Tomei UEL's when the flex pipes went and with both it has hissed when off throttle and coasting. Can't hear any other time because 3" Greddy Catback go brrrr
Charlotte, NC
14 Firestorm Red FR-S
GraysonGreene is offline   Reply With Quote
Old 05-14-2021, 01:14 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
The stock header has heat resistant insulation, fuzzy stuff, that surrounds the pipes, followed by a heat shield. Aftermarket headers don't have this shield or insulation, though you can wrap them and even stuff insulation into the wrap, and I'm sure that would cut the noise.
Mine hissed so much, @Ultramaroon thought I had an oil leak or something.
Old 05-14-2021, 04:29 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
Changed my whole understanding of how a lightweight tuned header should sound.
Old 05-14-2021, 05:11 PM   #14
Dububster
Dububster's Avatar
See mine only hisses when I am on the throttle in the lower rev range. I take a video and post it.
Hissing noise j_ros94 Forced Induction 7 10-07-2020 08:02 PM
Boosted brz hissing noise j_ros94 Issues | Warranty | Recalls / TSB 5 09-13-2020 01:40 PM
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 01:28 PM
Hissing/rattle from 3.5-4k RPM after OFT illmatic_frs Engine, Exhaust, Transmission 28 03-21-2017 08:02 PM
Hissing clutch noise FR-Sky Issues | Warranty | Recalls / TSB 32 02-16-2017 10:57 PM
