Old 05-12-2021, 10:58 PM   #1
jacobe38
jacobe38's Avatar
Drives: frs
Rotrex Idle Whine?
Hello all, hoping to get a bit of feedback on my new c30. installed today, and I wanted to verify this idle noise is normal. i move around a bit because its weirdly angle dependent on how clear you can hear the whine. as such i figure its coming from within the rotrex and what you hear is the sound echoing out through the tube and air filter.
what im trying to pick out is that high pitch whine. unsure if mechanical whine, or just the sound of air whistling, normal or not, etc. kind of hard to hear from inside, did not seem to get louder when i revved a bit.
just wanted to verify this is normal sounding for a c30 at idle. fluid reservoir is full
thanks!
jacobe38 is offline   Reply With Quote
Old 05-12-2021, 11:10 PM   #2
radroach
Drives: car
You should drive it to the dealership and say yeah I think there's a whine under there or something
Old 05-13-2021, 04:57 AM   #3
tomm.brz
Drives: brz 2017 hksv2
sounds normal to me , that 's just the suction noise of it
my hks gt2 sounds identical
You will know, when the sound won't be right
Old 05-13-2021, 11:56 AM   #4
jacobe38
jacobe38's Avatar
Drives: frs
thanks for the reassurance. it is a bit louder in person, that didnt come thru the video perfectly.
but this is my first time up close with a supercharger like this so, was getting anxious
Old 05-13-2021, 03:01 PM   #5
tomm.brz
don' t worry
The Following User Says Thank You to tomm.brz For This Useful Post:
jeepmor (05-25-2021)
Old 05-25-2021, 12:44 PM   #6
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Sounds normal. HKS version over here, sounds very similar to mine.
jeepmor is offline   Reply With Quote
Old 05-25-2021, 01:13 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You did properly prime it before starting, correct?
My c30 got louder and louder as it failed. Got so loud you had to cover your ears standing next to the car.
Old 05-27-2021, 02:01 PM   #8
Sounds normal. I hear air filter, not whine.
Whine when accelerating Geex Issues | Warranty | Recalls / TSB 9 07-21-2018 03:35 PM
Hum/whine when decelerating GeeTee86 Issues | Warranty | Recalls / TSB 10 08-11-2016 12:01 PM
Trans whine? MisterSheep Issues | Warranty | Recalls / TSB 50 02-12-2016 10:37 AM
2013 FR-S A/T whine.... Tromatic Engine, Exhaust, Transmission 6 01-20-2014 12:57 PM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-17-2013 11:00 PM
