Southern California SoCal
Old 05-10-2021, 02:03 PM   #1
xenex
Drives: 2014 Scion FR-S Monogram Series
Oil leak, recommended dealerships in LA/OC?
I have a FRS that has been leaking oil for some time now. I haven't noticed any pools of oil on the ground, although the skidplate is black/dirty as hell and I noticed the leak when the oil was changed. Factory warranty is about to expire next month and I'm looking to get it fixed but the horror stories of dealerships and oil leak repairs are concerning. Any recommended dealerships in LA/OC from people that have had good experiences with oil leaks being resolved?
The oil leak:
xenex is offline   Reply With Quote
Old 05-10-2021, 02:20 PM   #2
89_Manny
89_Manny's Avatar
Drives: Firestorm FR-S '13
Longo Toyota in El Monte. I’ve had some work and diagnostics done there. And it has always been a great experience
89_Manny is offline   Reply With Quote
The Following User Says Thank You to 89_Manny For This Useful Post:
xenex (05-11-2021)
Old 05-10-2021, 02:33 PM   #3
Curious how you have a 14 that still has factory warranty?
Decimus (05-10-2021), soundman98 (05-10-2021)
Old 05-10-2021, 03:03 PM   #4
xenex
That's where I actually bought my car from and was thinking about going there. Glad to see someone else recommended them. What work did you have done specifically if you don't mind me asking?
Yeah, I suppose I should have said CPO warranty, good until June 2021 or 100k miles.
The Following 2 Users Say Thank You to xenex For This Useful Post:
Decimus (05-11-2021), Tcoat (05-10-2021)
Old 05-10-2021, 03:46 PM   #5
whataboutbob
AutoX-10/10ths every run
Oil leaks from the engine front cover seal near the water pump were more common on the MY 2013-2014 cars. My original motor had this issue. I never got it fixed.
Build thread:Here
Old 05-10-2021, 04:30 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Anywhere but Irvine Toyota. They destroyed my car
Old 05-10-2021, 05:29 PM   #7
xenex
Yeah, I have had this leak for 2 years or so without getting it fixed. I figured that I might as well get the issue fixed before the warranty is expired. Not smelling burnt oil would be nice too.
Noted haha.
Old 05-10-2021, 07:37 PM   #8
JSIdriver51
Drives: 2014 Subaru BRZ WRB
The oil leak:
I’ve heard and know a good tech (Mauricio Knox) at the Toyota in Cerritos. Additionally, if you end up not being able to get it fixed in time, you can just clean the area and layer RTV to stop the leak (it’s what I did and has been good for the past year)
JSIdriver51 is offline   Reply With Quote
The Following User Says Thank You to JSIdriver51 For This Useful Post:
xenex (05-11-2021)
Old 05-11-2021, 12:01 AM   #9
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Such a common problem. I hate it and also have it. Going to eventually silicone/ RTV it as well.
Lucky you have warranty still.
Decimus is offline   Reply With Quote
Old 05-11-2021, 12:40 AM   #10
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
I second the Longo suggestion. They know how to seal timing covers on the FA20.
Sent from my SM-G986U using Tapatalk
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
xenex (05-11-2021)
Old 05-11-2021, 12:41 PM   #11
TAKECLEAR_86
TAKECLEAR_86's Avatar
Drives: 2017 Toyota 86 Halo
Northridge Toyota if you're close to the Valley. Had a leak in that exact same spot on my car, they fixed it up and I haven't had any issues since. It's been close to 15k miles since too.
TAKECLEAR_86 is offline   Reply With Quote
Old 05-13-2021, 01:44 AM   #12
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
Timing cover leak is what that looks like to me. It is like a 13 hour job. Make sure that wherever you take it, you ask for their master mechanic to take care of it. Not an easy job. Oil change and coolant flush are suggested when doing this job.
mod on
ric342 is offline   Reply With Quote
Old 05-19-2021, 11:36 PM   #13
jflogerzi
jflogerzi's Avatar
Longo would be my pick and its under warranty so any dealership should take it if the CPO was from Toyota. They get the book rate and will beat it so its easy money for them.
2013 Series 10 FRS #553
Old 05-20-2021, 12:02 AM   #14
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I had a very mild timing cover leak right above the hose in the pic on my 2013. I just lived with it, and kept it clean. After I took it in for the dreaded valve spring recall, the leak was gone. That was about a year and a half ago and it's been clean since.
shiumai is offline   Reply With Quote
Any recommended South Jersey Dealerships? Panchone NY / NJ / CT / PA 2 09-22-2019 06:47 PM
Dealerships to buy from in the SE Dave-ROR Southeast 86 01-26-2017 01:26 AM
Dealerships & Mods? _j_anthony Scion FR-S / Toyota 86 GT86 General Forum 11 09-06-2014 12:47 PM
Mod-friendly Dealerships clzzical Southern California 3 10-17-2012 12:00 AM
BRZ's have hit the dealerships in GTA 01s0uljah CANADA 43 06-23-2012 12:15 AM
