Drives: SWP Subaru BRZ
What rearbrake setup for Brembo Front BBK?
Currently running the Brembo GT Front BBK with Subaru OE Pads.
Currently looking at the T2 Slotted Rotors for the rear, and planning to pair that up with Subaru OE pads as well. Just curious what you guys are running for the rear brakes? And if so, do you guys have any other recommendations? This setup isnt for occasional track use. Mainly for street/dd, and maybe 1-2 track days a year. |
Any decent pad is gonna squeal. I run carbotech but I switch my pads between 1521s and and xp10/xp8 setup with.
2013 Series 10 FRS #553
Wheels for Brains
Unless you know you want to change the braking or handling character, use the same brake compound front and rear.
If you don't mind swapping pads and bedding the brakes in for every track day, get a dedicated set of track pads. You can also daily track pads, but they require more maintenance and go through rotors much faster. Depending on your speed and skill level, you might be able to get away with hybrid/sport pads for dual duty use. For rotors, don't need anything more than blank rotors for the rear. |
30 minute maintenance
Drives: My18 wrxsti
I run DBA T3 on the front and T2 on the rear with DBA XTreme Performance pads
Drives: 2022 GR86
If you only see a couple of track days per year, and have a decent pace, just get a dedicated set of pads for the track, and run OEM pads (or other street pad) for the street.
Swapping pads is not that hard, and any dual duty pad will suck either at street driving, or at track driving — one way or another. |
Drives: 2016 Scion FRS Release Series 2#439
I'm running T3 rotors all around with the CTS BBK front upgrade and EvoX rear upgrade.
Stoptech Sport pads are working for me. 98% DD and several track days last year. I fully expect to be replacing the pads soon but may choose the same. I'm having a hard time wrapping my head around changing back and forth between compatible street and track pads and the ~CA$1000.00 cost of those four corner sets of Carbotech 1521 and XP12 pads. Perhaps once I retire and have time to burn the switch-over may be okay. |
| Tags |
| bbk, brembo, brembo bbk, brembo gt |
| FS: Brembo sti front callipers | bass_114 | Canada Classifieds | 11 | 08-22-2017 09:52 AM |
| Brembo GT BBK Front and Rear | ThatBlueBRZ | Canada Classifieds | 3 | 05-03-2017 11:53 PM |
| EVO 7 BREMBO FRONT BRAKES ON BRZ? | NOTORIOUS.BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-26-2016 12:24 AM |
| Brembo front BBK Yellow | kasimmmmm | Brakes, Suspension, Chassis | 1 | 06-20-2015 01:49 AM |
| FS: 2005 STI Brembo Front Calipers | SuiSid3l | Brakes, Suspension, Chassis | 11 | 05-28-2015 08:12 PM |
