Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 07-09-2017, 11:48 PM   #1
bass_114
bass_114's Avatar
Drives: wrb brz
FS: Brembo sti front callipers
hey got a set of gem 2015 sti brembo's loaded with hardware and pads, they had 10 000km on them when they were taken off. the paint is in very good condition.
These add loads of braking power you will not be disappointed plus all kinds of extra race car cred aesthetic points
950$--->780$ SOLD
FYI bolt on fitment, even with oem brz/frs mags just need 20mm wheel spacer.
shipping is available with very good rates
bass_114 is offline   Reply With Quote
Old 07-10-2017, 12:32 PM   #2
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
would these fit behind stock wheels?
RickyRacer is offline   Reply With Quote
Old 07-10-2017, 02:21 PM   #3
bass_114
bass_114's Avatar
Drives: wrb brz
yes with the help of 20mm spacers
Old 07-10-2017, 02:23 PM   #4
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
so you still need to use the OEM bracket that holds the brake pads correct?
Old 07-10-2017, 04:41 PM   #5
sIowbrz
Drives: 2015 brz
what rotors do you need to run with these? also more brake pedal travel after these install?
sIowbrz is offline   Reply With Quote
Old 07-10-2017, 10:42 PM   #6
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
-2004 Impreza STI Calipers
-I didn't notice more brake travel with mine
projek_01 is offline   Reply With Quote
Old 07-10-2017, 11:32 PM   #7
bass_114
bass_114's Avatar
Drives: wrb brz
that bracket is removed, the brembos bolt straight to the wheel hub
Old 07-10-2017, 11:35 PM   #8
bass_114
bass_114's Avatar
Drives: wrb brz
any brand rotors that fit the front of an sti 2004 will fit.
no more brake travel than usual but you put less effort into braking just because they have stronger braking capabilities. let's say you push the pedal 30% to come to a stop with these you would put 10% of that pressure dunno the simplest i can put it...you get used to it
Old 07-11-2017, 12:48 AM   #9
sIowbrz
Drives: 2015 brz
Wait but the newer sti rotors is 5x114.3 how would brz 5x100 run their rotors
Old 07-11-2017, 12:55 AM   #10
Vten
Drives: Too heavy
Either redrill the existing rotor or upgrade to dba t3 dual pattern rotors
Vten is offline   Reply With Quote
Old 07-11-2017, 08:35 AM   #11
bass_114
bass_114's Avatar
Drives: wrb brz
you are correct my error...any brand 2004 STI rotors will fit or the dual drilled as mentioned
Old 08-22-2017, 09:52 AM   #12
bass_114
bass_114's Avatar
Drives: wrb brz
lowered price
Brembo GT BBK Front and Rear ThatBlueBRZ Canada Classifieds 3 05-03-2017 11:53 PM
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 12:24 AM
Brembo front BBK Yellow kasimmmmm Brakes, Suspension, Chassis 1 06-20-2015 01:49 AM
Callipers nzer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-09-2013 04:46 AM
