Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 04-30-2021, 06:18 PM   #1
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
Bang & Lazar Strut Tower Dust Covers for Coilovers / Camber Plates
This is more of a FYI for anyone that has looked/is looking for dust covers post coilover install than it is a review. There isn't much to actually review and they are just as advertised... a 3D printed cap to go over the strut tower if you have replaced the OEM suspension with coilovers and/or camber plates. And they have little artifacts and a seam on each one as expected and as notated in their description.
They do offer a few different colours and you can get them with different emblems/logos. If you happen to need additional space you can request the taller version when you checkout. They are based in Denmark and with all the shipping oddities because of CV19, I opted for the upgraded tracking that provided a tracking number. They took about 30 days to get here and that includes the 9 days they were stuck in Customs when they arrived at O'Hare from Copenhagen.
I think that about covers it aside from some measurements and pictures. Oh! They are really tight so take your time and do as they suggest. I started with a blade perpendicular to the edge to scrape off little artifacts and stringy leftovers from the 3D printer. After that I did the suggested slow turns and pushed down firmly along the edges until they popped in.
Bang & Lazar: https://banglazar.com/collections/gt...32836814831661
Dust Bowl
I have the CSG Tein Flex A and the stem is above the edge by about 2cm with the rubber cap.
Standard caps have 2.5cm of space between the underside of the cap and the stem. (3cm to the edge minus 5mm for the edge of the cap that goes into the strut tower) If your adjustment stem is more than 2.5cm above the tower edge, go with the taller version.
therealstoly is offline   Reply With Quote
The Following 4 Users Say Thank You to therealstoly For This Useful Post:
BRZyJ (05-01-2021), Plumbus (05-03-2021), SCFD (05-04-2021), vintagemxer (05-03-2021)
Old 05-04-2021, 07:11 PM   #2
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Though a very simple idea, this is genius. It's been only a few months since I got my coilovers but the ball bearing in the top hats is already getting clogged with plant and insect crap. It's a great way to wear those parts prematurely by ruining the self lubrication of the bearing. Definitely getting this.
Plumbus is offline   Reply With Quote
The Following User Says Thank You to Plumbus For This Useful Post:
therealstoly (05-04-2021)
Old 05-04-2021, 07:17 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
FYI most of those dirt are coming from the bottom instead of top. From the top, you only get is here and there dusts.
Still it's an interesting parts none the less.
ka-t_240 (05-30-2021)
Old 05-04-2021, 09:46 PM   #4
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
My car lives under a giant gross tree that shits leaves, sap, artillery fungus, bird shit, and tons of dust from all the dry leaves breaking apart. The engine bay is full of leaves and insect husks get in every nook and cranny as well. I'm sure a bunch comes from underneath but for me most of it is from above in my case.
therealstoly (05-06-2021)
Old 05-04-2021, 10:20 PM   #5
Joon525
Joon525's Avatar
Drives: 2016 BRZ
You MIGHT have trouble with some camber plates in conjunction with these.
Raceseng's actually have a portion that rises UP in the opening. Maybe you will be lucky enough to use them if there's enough space to let the lip of this do its thing.
Other camber plates are perfectly flat and thus cause less of a problem.
This
vs
Also, even if you have a flat camber plate your camber setting could be pushing the locking bolts right up to the edge of the opening (depends on the brand and your setting) but you could notch the lip.
Just something to look out for. These aren't a bad idea but as the other guys mentioned, a lot of dirt comes from UNDER the plate. Still though, not a bad idea.
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
Old 05-06-2021, 10:41 PM   #6
Chuckls
Moutain Runner
Rubber mallet go BRRRR.
I just sent it. THey popped in.
Chuckls is offline   Reply With Quote
The Following 3 Users Say Thank You to Chuckls For This Useful Post:
NoHaveMSG (05-06-2021), therealstoly (05-06-2021), vintagemxer (05-25-2021)
Old 06-24-2021, 11:33 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have no interest in these because track car.. but how easy are they to remove for adjustments? I like the clean look of them just curious on the level of pain in the ass for removal.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Jdmjunkie (06-24-2021)
Old 10-31-2021, 06:36 AM   #8
gpvecchi
gpvecchi's Avatar
Pure bullshit and worst customer service. For my first order I received a wrongly packaged baby t shirt, they claimed to send a replace, but I never received. After menacing a PayPal claim I got my money back, so I bought another set.
Received, and they don't fit. They are about 1 mm bigger than the seat.
gpvecchi is offline   Reply With Quote
Old 11-01-2021, 11:13 AM   #9
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Mine were tight but they come put pretty easily and go back in just as easily.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
FS: Password ahem Covers, GS Strut Bar, RSR Coilovers TOZER Canada Classifieds 7 05-10-2020 06:44 PM
KW coilovers and camber (without camber plates) wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2018 08:53 PM
Bent Strut Tower and Camber Plate finch1750 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 07-13-2017 07:54 PM
FS BC BR Coilovers & Oni Camber Plates SLICVIC Brakes, Suspension, Chassis 0 03-01-2015 02:10 PM
FS: Coilovers W/ Camber Plates $575 Amir Ghadiri Brakes, Suspension, Chassis 8 03-11-2014 02:22 AM
