Old 03-01-2015, 03:10 PM   #1
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
FS BC BR Coilovers & Oni Camber Plates
For Sale a pair of Aluminum Oni Camber plates that fit BC Coilovers. These are a direct replacement of the existing BC Adjustable tophats. The camber range is around up to -6 degrees with the tophats alone.
Looking to get $225 firm
SOLDSOLDSOLD
For Sale is my old set of BC BR Coilovers with 10k springs all around, Rears have damper extenders. Includes Camber bolts with special washers to avoid slipping.
Fronts were heavily modified for Camber- Slotting top holes , Swaybar and brake line bracket deleted (brakelines were secured to ABSsensor bracket, and swaybar was deleted)
coils have about 3k miles on them. Located in Bronx NY , Will ship at buyers expense. One of the top plate stud's threads are a bit crossthreaded, BC sells replacement studs
For quickest response you can reach me at vic(dot)morales87(at)yahoo.com
SLICVIC is offline   Reply With Quote
FS: Raceseng Camber Plates (for KW/Tarmac coilovers) Sportsguy83 Brakes, Suspension, Chassis 2 01-21-2015 05:24 PM
FS: KW V3 Coilovers w/ Vorschlag Camber Plates rever5e Brakes, Suspension, Chassis 10 12-30-2014 07:24 PM
Have ST Coilovers. Want Klutch SL14 18/8.5F,18/9.5R. Need Camber Plates? Namuna Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-27-2014 09:15 PM
FS: Coilovers W/ Camber Plates $575 Amir Ghadiri Brakes, Suspension, Chassis 8 03-11-2014 03:22 AM
FS: Robispec KW VIII Coilovers + Camber Plates etc sw20kosh Brakes, Suspension, Chassis 10 02-28-2014 03:17 AM
