Old 04-30-2021, 12:04 PM   #1
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
Header to Overpipe Gasket?
I'm planning a header install soon, and I"m just making sure I have everything.
I know that these are the header gaskets (Grimmspeed), but I'm not sure which gasket I need for the header-to-overpipe connection. Will this Remflex work? Or should I go OEM?
jkamelo is offline   Reply With Quote
Old 04-30-2021, 12:08 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I just stick with the OEM. It's good enough for government work. Though Grimmspeed has the header to overpipe gasket too:
https://www.rallysportdirect.com/par...ket-2-25-2-5in
MS, CSCS, TSAC-F, CPT
Old 04-30-2021, 12:11 PM   #3
dasting
Drives: 2013 BRZ Limited
I used this a few months ago and it worked fine. https://www.amazon.com/gp/aw/d/B00CC...b_b_asin_image
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
Old 04-30-2021, 12:25 PM   #4
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Grimmspeed also has the gaskets you'll need. https://86speed.com/grimmspeed-exhaust-gasket-kit
The Following User Says Thank You to spcmafia For This Useful Post:
jkamelo (04-30-2021)
Which way to install oem gasket for exhaust manifold/overpipe Sangthing Engine, Exhaust, Transmission 1 04-02-2017 02:14 PM
Header Gasket tofurun Engine, Exhaust, Transmission 21 08-23-2016 05:55 PM
Overpipe gasket exhaust leak THEWAKLER Engine, Exhaust, Transmission 19 11-29-2015 01:38 AM
WTB header Gasket Krazy Want-To-Buy Requests 5 06-17-2015 03:59 PM
Revworks UEL gasket for stock overpipe wbradley Engine, Exhaust, Transmission 12 02-26-2015 09:42 AM
