Old 08-21-2016, 10:21 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Header Gasket
So many have said that the oem header gaskets will fail on an aftermarket catless header. I was going to get the grim speed headers and call it good. Then while looking at the JDL auto headers I am going to order i see they offer this sweet kit with the gaskets and locking nuts so I don't have to go back a re torque the header nuts! The only problem is that it says it come with "Pair of OEM header gaskets" lol. I would link their site but I dont think i can. Any opinions on whether I should stick with the Grimspeed or will the ones JDL auto offer work just as good? @ATL BRZ wana chime in??
The picture is the JDL gaskets that says theyre OEM. dont look oem to me
tofurun is offline   Reply With Quote
Old 08-21-2016, 10:39 PM   #2
Teseo
Drives: frs
I bough the uel header with the promo of 86 fest. Came with oem gaskets and their locknut package. Basically that offer is plug and play, came with the hardware you need to install it. You cant go wrong with jdl header, and their warranty is hard to beat. After a heat cycle i re-torqued for peace mind but is not needed.
Old 08-21-2016, 10:50 PM   #3
FRS Justin
Drives: 2013 Asphalt FRS
WRX OEM gaskets
http://importimageracing.com/oem-sub...2002-2014.html
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 08-22-2016, 12:46 AM   #4
humfrz
Sorry, I don't understand the question ......
Are you asking which header to buy or which header gaskets to use ..... ??
humfrz
Old 08-22-2016, 09:38 AM   #5
celek
Resident Gear Head
celek's Avatar
Old OEM EJ dual port gasket
Same part number from late 1990s to now
New style is Stainless steel embossed gasket
celek is offline   Reply With Quote
Old 08-22-2016, 10:43 AM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Grimmspeed gaskets FTW
Old 08-22-2016, 11:09 AM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm running the JDL gaskets with a Nameless header, which is notoriously tricky to keep from leaking I guess... I did have a leak, but not from these gaskets - it was at the header>overpipe where the bolts I have were really tricky to use. YMMV.
Old 08-22-2016, 11:19 AM   #8
tofurun
tofurun's Avatar
humfrz
Lol gasket. Trying to see if the jdl gasket performs as well as the grimmspeed
Old 08-22-2016, 11:40 AM   #9
humfrz
Well, OK.
I don't think it would make any difference. It's not so much the gasket (as long as it fits) as how the header is tighten up against the head.
I'd make sure the header fits snug (when it is relaxed) put the gasket in place, then tighten the nuts, moving from one to the other, a little at a time, until they are "manifold nuts tight" ...... or your favorite torque specification.
Heck, back in the day, we used to "make" (cut our own) manifold gaskets out of a sheet of asbestos. Be damned the dust ...... we were bullet proof .... actually we didn't know .....
humfrz
Old 08-22-2016, 11:57 AM   #10
tofurun
tofurun's Avatar
Well, OK.
humfrz
Why do the stock gaskets fail on the aftermarket headers??
One day Ima buy u a beer old man
Old 08-22-2016, 12:19 PM   #11
humfrz
Well, I would guess that the OEM gasket was being re-used was compromised when the old header was taken off .......
OR
the OEM gaskets can be thinner because the OEM header fits better......
OR
the robot that tightened down the OEM header did a better job
Hey, I'll take you up on an iced tea ....... I had to quit drinking 20 some years ago ....... the whisky was getting too strong .......
humfrz
Old 08-22-2016, 12:30 PM   #12
tofurun
tofurun's Avatar
OR
OR
humfrz
Only iced tea I got is sweeeeeeeeeeeeeet tea!
Old 08-22-2016, 01:04 PM   #13
humfrz
Well, of course ....... how else would they serve it in Georgia ...... ??
humfrz
Old 08-22-2016, 01:13 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
I used new OEM gaskets when installing a Revworks catless UEL header. Works like a charm after 2 years. Perhaps if you have issues with an aftermarket header where the end plate (or whatever you call it) isn't completely flat where it meets the exhaust port.
Need help with Donut Gasket xcooperx Southern California 3 08-16-2015 12:50 PM
WTB header Gasket Krazy Want-To-Buy Requests 5 06-17-2015 03:59 PM
Header Gasket Questions gepeyo Northern California 11 02-02-2015 10:51 PM
Need to replace FP/MP gasket when installing header? 1Cor10:23 Engine, Exhaust, Transmission 16 04-24-2014 04:09 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
