Old 04-25-2021, 11:31 PM   #1
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
OFT or Dyno for first tuning?
I have no experience in tuning cars so I'm kinda on the fence with this process. Everything is stock besides a K&N drop in filter and I plan on getting Tomei UEL headers and an MXP Comp RS catback exhaust. Now I know you have to tune it after installing them but what would be the best route.. oft or a local dyno shop. If it matters I plan on buying the Vishnu oft tab 2.0. Also after installing headers/exhaust should I start with a stage 2 tune?
blakkoutdarko is offline   Reply With Quote
Old 04-26-2021, 08:24 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Budget is the main difference. If dyno tuning is on the table I would talk to your local shops and see if/what Software they recommend.
Oft will provide you with canned tunes. You can also perform custom tuning. Dyno tuning is doable but I know the flash process and talk between open flash manager isn't exactly a speedy process.
I did street tuning with a custom oft tune and sending logs via email.
The Following User Says Thank You to RToyo86 For This Useful Post:
blakkoutdarko (04-28-2021)
Old 04-26-2021, 11:51 AM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
OFT gives you the convenience of switching between tunes with the touch of a button, stock to stage 2+ and E85. The only drawback is that you get a somewhat standardized power gain.
EcuTek or custom tune will cater to your mods extracting every single HP it can.
I guess it should be a good rule of thumb that if you're staying N/A, stick with OFT. If you're planning on boosting, you can always sell the OFT and get Ecutek.
Lastly, regarding OFT, if your headers are UNCATTED you will download the Stage 2+. If they are CATTED, is just a normal Stage 2. Check this link from OFT.
https://support.openflashtablet.com/...e-requirements
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
blakkoutdarko (04-28-2021), jflogerzi (04-26-2021)
Old 04-26-2021, 01:02 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
Ecutek map switching is way quicker and easier than OFT if you have multiple maps.
Get a used OFT 1st, slowly do your mods, once you’re done with FBO sell the OFT for no loss, and get a custom ecutek e-tune. Or you could hit up wayno or steve for a custom OFT tune.
Old 04-26-2021, 01:27 PM   #5
jflogerzi
jflogerzi's Avatar
IMO unless your going Flex Fuel, OFT is the way to go. Get your OFT tune dialed in once all your mods are done as mentioned with Steve or Waymo.
OFT NA and 91/93 and want to run e85 from time to time
Ecutek for Boost or Flex Fuel on NA
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
blakkoutdarko (04-28-2021), norcalpb (04-28-2021)
Old 04-26-2021, 02:06 PM   #6
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I would not get a tune with vishnu/OFT since their turn around time is ridiculous. I would do the OFT with Steve though as he is highly knowledgeable and I refer him to everyone.
Otherwise go with EcuTek/Local.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Old 04-28-2021, 10:16 AM   #7
blakkoutdarko
Yeah the convenience of the oft is what got me sold on the product and my local dyno shop is kinda pricey from what I see + they mostly cater to Hondas. But in YouTube reviews Ive watched it seems like its a pretty swift process maybe I'm wrong
Old 04-28-2021, 10:16 AM   #8
blakkoutdarko
How can I get into contact with Steve?
Old 04-28-2021, 10:20 AM   #9
RToyo86
RToyo86's Avatar
@steve99 .
@tomm.brz did my custom tune. Quite happy with the end result.
Old 04-28-2021, 10:23 AM   #10
blakkoutdarko
Yeah for now I plan on staying n/a but I will def give the oft a try just to experiment with and I'm gonna do more research on the EcuTek since it seems like the more advanced product compared to oft but thanks
Old 04-28-2021, 10:26 AM   #11
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
He's a member on here and also active on facebook groups as well to give free support to people with problems.
Clueless
Old 04-28-2021, 10:28 AM   #12
blakkoutdarko
@steve99 .
thanks for the reference man definitely hitting them up soon
Old 04-28-2021, 10:30 AM   #13
blakkoutdarko
Yeah this seems like the most reasonable route. much appreciated!
OFT dyno tuning in the PA/NJ area? nickmerronesucks NY / NJ / CT / PA 12 12-13-2015 09:56 PM
Equilibrium Tuning Dyno Day! Patrick@EQTuning Northern California 3 06-17-2015 02:56 PM
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Dyno Nights @ FR&R tuning GeeTee86 AFRICA 1 06-25-2013 04:25 AM
