Old 04-22-2021, 10:57 PM   #1
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Unhappy Corsa mid-pipe resonator touching subframe?
When I had my coilovers installed the tech noticed the resonator on my Corsa mid-pipe was touching the subframe and noted nothing could be done. I installed it myself without issue and didn’t notice...
There is a small “browning” effect happening and not sure if I should be concerned? I was thinking of simply putting some heat tape on the body between the exhaust and the resonator. Will this work?
Thank you, as always!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-22-2021, 11:26 PM   #2
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Crap..wasn’t thinking...could a mod move this to the exhaust sub-forum, please?
Old 04-23-2021, 05:40 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You can try rotating that pipe section so the bend section near the diff faces more downward. That may push the resonator farther away. I can't recall that being an issue for me.
I was able to change the exhaust tip position by moving that up/down.
The Following User Says Thank You to RToyo86 For This Useful Post:
BrahmaBull1990 (04-23-2021)
Old 04-23-2021, 08:56 AM   #4
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
So maybe I just put the mid-pipe on the wrong way? That could be an easy fit. Would I need new gaskets if I loosened, rotated, and retightened?
Old 04-23-2021, 09:02 AM   #5
RToyo86
RToyo86's Avatar
You'll be fine. There is only the one gasket where it meets the front pipe. Mine was in good condition after 2 years.
I will have a look at my system In the basement when I get home. It's possible the first mide pipe section is upside down where it bolts up to the front pipe. I recall there being a slight bend which would definitely effect alignment further down if it was wrong.
I'm fairly certain the rear slip joint section of the midpipe has the exhaust hanger attached. There would be no way to mix that up. But you can rotate it a bit if you notice one exhaust tip sticks out farther than the other.
Old 04-23-2021, 09:12 AM   #6
RToyo86
RToyo86's Avatar
There is definitely a bend in the first section. Check to see which way it's oriented. I believe the bend is meant to shift the pipe towards the passenger side of the vehicle.
I recall mine sitting close in that spot. You could try loosening everything up and wiggling the metal exhaust hanger on the rubber bushing thingy to pull it away.
Old 04-23-2021, 09:36 AM   #7
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
This is really helpful. I guess I have my weekend project, thank you!
Old 04-23-2021, 12:52 PM   #8
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Just got off the phone with Corsa support and he basically said "idk" and I was SOL lol
Old 04-27-2021, 08:35 PM   #9
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Update: loosened the mid-pipe to front pipe flange; pried the resonator away from the body; retightened; all good in the hood now
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
Dzmitry (04-29-2021), RToyo86 (04-27-2021)
Invidia catback and resonator pipe mib911 Engine, Exhaust, Bolt-Ons 0 01-08-2021 11:29 AM
Corsa Exhaust overpipe/front pipe combo SuperFlyMerks Engine, Exhaust, Transmission 11 01-08-2018 12:32 PM
Over pipe taps subframe ckellykcco Engine, Exhaust, Transmission 5 02-26-2016 08:31 AM
Ark Front Pipe w/ Hemholtz Resonator k.houan Engine, Exhaust, Bolt-Ons 1 11-11-2015 12:34 PM
Best resonator to add to mid-pipe? akahenry Engine, Exhaust, Transmission 9 09-18-2014 04:31 AM
