Old 04-15-2021, 06:22 PM   #1
Volkyrie
Volkyrie's Avatar
Drives: 2017 BRZ PP
Beastronix Fan Switch Question
Hey folks, I just picked up a used 2017 BRZ with a Beastronix v1 installed.
I noticed that the radiator fans are always on when the engine is on, regardless of the fan switch position. Can anyone tell me if this is working as expected or not? If it is, what does the switch do?
Volkyrie is offline   Reply With Quote
Old 04-16-2021, 11:24 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Every install was a little different. Hard to say. Also a/c on runs both fans. Need more info/troubleshooting. You should be able to unplug the beastronix and the behavior should be factory at that point.
Since beastronix is no more, what’s the alternative? Four_wheel_drifts Tracking / Autocross / HPDE / Drifting 299 10-03-2022 01:52 PM
Oft Stage 2 e85 switch over question bdtbdtbdt Software Tuning 5 08-21-2020 04:27 PM
Cam solenoid switch question Rabrooks Engine, Exhaust, Transmission 2 02-15-2020 01:12 AM
Beastronix Install HoonThis Software Tuning 4 06-08-2017 11:02 PM
Window and door lock switch Illumination question. HapaHaole BRZ First-Gen (2012+) — General Topics 0 03-05-2014 10:14 PM
